launch problems
Old Sep 20, 2004 | 08:04 AM
goose21's Avatar
Default launch problems
I have some problems with my launch since i got the turbo. The biggest problem is my slicks are to little(20/8/14). Now when i launch i have allot of wheelspin in 1st gear. But when i shift to 2 gear my rpm's fall's back dead to 4500 rpm.
what would be the best way to launch????
I shift from 1 to 2 gear @8500rpm
here is my dyno. Maybe it help's
Modified by goose21 at 9:16 AM 9/20/2004
Old Sep 20, 2004 | 08:32 AM
ComputerJLT's Avatar
Default Re: launch problems (goose21)
if you shift from 1st to 2nd and your rpm's fall that much you have WAY too long of a 2nd gear gearing or you're shifting early.
i know you say you have willspin in first but do you ride it until the engine hits 8.5k w/ spin and shift;
or do you shift @ 8.5k because that happens to be the rev limit and you're riding it until you run out of speed in first
Old Sep 20, 2004 | 08:38 AM
DSF's Avatar
DSF
Default Re: launch problems (ComputerJLT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComputerJLT &raquo;</TD></TR><TR><TD CLASS="quote">
or do you shift @ 8.5k because that happens to be the rev limit and you're riding it until you run out of speed in first</TD></TR></TABLE>
Yeah. If you're shifting as soon as you hit 8.5k then your not allowing the car to get up to speed causing the large rpm drop to second. You need to let the car catch up to the wheels. Oh, and this should really be in the drag racing forum.
eMpAtHy
Jan 22, 2009 10:42 AM
buzlink
Nov 19, 2005 05:03 PM
blackrex
Mar 18, 2005 05:37 PM
