Vacumn source
Old Sep 17, 2004 | 04:32 PM
tub_sephiroth's Avatar
Default Vacumn source
Where do I find a vacumn source that's after the intercooler and before the throttle? I'm getting boost leak, and I think it's my vacumn source. Right now, the vacumn is hooked to the nipple on the turbo to the mbc to the wastegate. I've read that to hook it up to the intake manifold. All the sources I found were after the throttle though.
Old Sep 17, 2004 | 06:35 PM
jamartin0519's Avatar
Default Re: Vacumn source (tub_sephiroth)
A lot of people run their vacuum lines off of the brake booster.
Old Sep 17, 2004 | 07:36 PM
silverb18's Avatar
Default Re: Vacumn source (jamartin0519)
is there any problems with hooking up the vaccum line from the turbo to the wg?
Old Sep 17, 2004 | 09:43 PM
inspyral's Avatar
Default Re: Vacumn source (silverb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverb18 &raquo;</TD></TR><TR><TD CLASS="quote">is there any problems with hooking up the vaccum line from the turbo to the wg?</TD></TR></TABLE>
Nope, that works fine. You might not see the full amount of boost your w/g spring is rated at running the vac line from there though(pressure loss through the i/c, etc).
Old Sep 17, 2004 | 10:29 PM
djfob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamartin0519 &raquo;</TD></TR><TR><TD CLASS="quote">A lot of people run their vacuum lines off of the brake booster.</TD></TR></TABLE>
This is where I tapped for vac source.
19_HaTcH_92
Feb 20, 2010 03:24 PM
Maple50175
Jul 27, 2008 04:07 PM
The Dirty EJ1
Jun 10, 2007 02:31 PM
jure
May 9, 2004 08:34 AM
FastNFurious
May 7, 2003 01:00 PM
