Blue Box Questions.
Old Sep 19, 2004 | 03:35 PM
EJ8 D15Y8's Avatar
Default Blue Box Questions.
Whats up guys.
Putting a kit together, and just want some cheap management. A pal of mine has a blue box on his y7, and its decent. So I want the same. No time to tinker, just want to slap it in and go, thats why im choosing the blue box.
I have a 97 civic Ex. It has a y7 head/ b7 block obd2-1 and chipped p05.
My question is can I use any blue box ?
Ive seen one for sale for a 99si. Im not sure if the obd2 blue box would work with my obd1 ecu.
Any ideas ? Is the blue box obd2/1 compatible ?
Thanks.
Old Sep 19, 2004 | 05:44 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Blue Box Questions. (EJ8 D15Y8)
Wondered the same thing a few months ago.
When I find the information in search, I'll post the thread in here.
Old Sep 19, 2004 | 07:28 PM
EJ8 D15Y8's Avatar
Thank You.
Old Sep 19, 2004 | 07:41 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (EJ8 D15Y8)
If you use a Blue Box from a 92-95 greddy kit, it will work fine.
Personally, I'm running a greddy blue box from a 92-95 kit on my OBD-II P2P stock EX ecu. Got the diagram off of turbocivic.net , but the site is down.
Go to http://www.turbod16.com under the FAQ section to see the wiring diagram.
It will probably work, but I'm not sure how well with a chipped ecu vs. stock.
Hope that helped.
Old Sep 20, 2004 | 11:07 AM
EJ8 D15Y8's Avatar
Thanks.
Im aware that the 92-95 blue box will work on an obd2 ecu. Tried it on my friends y7.
"It will probably work, but I'm not sure how well with a chipped ecu vs. stock."
Im not worried about being chipped. I can always get a stock p28 program for 10 bucks.
Im worried if the obd2 si blue box would work on my obd1 ecu. Period.
Thanks for the reply.
Old Sep 20, 2004 | 12:36 PM
JOSEPH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 D15Y8 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks.
Thanks for the reply.</TD></TR></TABLE>
it will work, but the Si blue box is designed to use the 310 cc injectors that come with the kit.
Old Sep 20, 2004 | 02:43 PM
EJ8 D15Y8's Avatar
Thanks for the info.
So do you think it would run correctly with stock 240cc injectors.
Thanks again.
Old Sep 20, 2004 | 08:34 PM
Can you not read? He says it's calibrated for 310cc injectors, not your stock 240's.
Old Sep 21, 2004 | 12:35 AM
AF-b16a1's Avatar
yah i need to change my injectors cause it feels like the car is runnin weird with my 240's and the blue box...
Old Sep 21, 2004 | 06:11 AM
EKhothatch's Avatar
Default blue box w/ stock injectors
Actually the OBD1 blue box that is non-tunable is designed to run off the factory 240cc injectors that come in the 92-95 civic si/ex models. The kit doesn't come with replacement injectors.
And yes, the blue box should would work fine with the OBD1 ecu. That's what it's meant to run on. It also runs fine on the OBD2 motors and ecus (ex dx lx cx). I ran it on my 96 civic dx with an z6 motor with the OBD1 ecu.
Old Sep 21, 2004 | 11:15 AM
EJ8 D15Y8's Avatar
I know he said its calibrated for 310's.
I wanted to know if it will RUN on stock 240's.
Relax a little bit, its not the end of the world.
Old Sep 21, 2004 | 11:25 AM
AF-b16a1's Avatar
it doesnt perform as well and it sputters at time
Old Sep 21, 2004 | 11:51 AM
EJ8 D15Y8's Avatar
Thank you. That was perfect.
Old Sep 22, 2004 | 05:51 AM
EKhothatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 D15Y8 &raquo;</TD></TR><TR><TD CLASS="quote">I know he said its calibrated for 310's.
Relax a little bit, its not the end of the world.</TD></TR></TABLE>
That's not what I said though. There not calibrated for 310's. Their calibrated for stock 240cc honda injectors.
Old Sep 22, 2004 | 06:15 AM
INVALID's Avatar
Default Re: (EKhothatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhothatch &raquo;</TD></TR><TR><TD CLASS="quote">
That's not what I said though. There not calibrated for 310's. Their calibrated for stock 240cc honda injectors.</TD></TR></TABLE>
He isn't referring to you, he was referring to this earlier post:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOSEPH &raquo;</TD></TR><TR><TD CLASS="quote">
it will work, but the Si blue box is designed to use the 310 cc injectors that come with the kit.</TD></TR></TABLE>
He is referring to a blue box meant for a OBD2 car though, from reading, yours is no longer OBD2.
cxjon
Dec 30, 2004 06:38 PM
flymecourageous
Jan 27, 2004 02:20 AM
Boostless97Lude
Sep 4, 2002 07:45 PM
