Trying to disconnect my vafc for uberdata
Old Sep 19, 2004 | 09:18 PM
uptownrickyv's Avatar
Default Trying to disconnect my vafc for uberdata
Yesterday i got my turbo setup finally finished and put in. After taking out the motor taking off the jrsc and old tranny putting all the new **** on... new turbo, tranny etc. I got started the car right up. This was on my stock obd2 ecu running the vafc.
Today i setup everthing for my uberdata basemap plugged in the harness and new obd1 ecu. I left my vafc wired in to the stock harness cause i didn't know how or what wires to disconnect. I figured i'd give it a try with the vafc still wired in. It started up... but bogged down right away. Is anyone here running uberdata/hondata and a vafc? I'm thinking not. Right now i dont have the instructions anymore to my vafc so i don't know what to disconnect and reconnect on the stock harness so my uberdata can work right. Any suggestions or help on what i should do? Thanks...
Old Sep 19, 2004 | 09:37 PM
safe driver's Avatar
Default Re: Trying to disconnect my vafc for uberdata (uptownrickyv)
were you using the afc hack previously? if you were, you need to zero out the fuel settings.
or else... http://www.apexi-usa.com/produ...c.pdf
Old Sep 19, 2004 | 09:41 PM
Default Re: Trying to disconnect my vafc for uberdata (safe driver)
How do i zero everything out? And when i do that... does that mean its just doing nothing after that? It'll be pretty much for show?
Old Sep 19, 2004 | 09:48 PM
setting->wide thr: change the hi and lo values to zero
setting->narr thr: change the hi and lo values to zero
after that the afc will be nothing more than a fancy guage.
Old Sep 19, 2004 | 09:52 PM
Bailhatch's Avatar
basicly, take the MAP sensor wire that goes to the ECU and reconect the 2 ends (it's the only ecu wire that is cut not just tapped into). then cut off all the rest of the wires and insulate with e-tape. now it's stock again.
Old Sep 19, 2004 | 10:15 PM
ScottEK's Avatar
Default Re: Trying to disconnect my vafc for uberdata (Bailhatch)
Isn't the VTEC Pressure switch and solenoid also cut?
Either way, you can run VAFC and uberdata, just do as he says and 0 everything out. Also it will still control your VTEC activation so set it accordingly. I still use my VAFC for a peak/hold RPM and pressure gauge.
Old Sep 19, 2004 | 10:41 PM
Default Re: Trying to disconnect my vafc for uberdata (beta13)
I think setting it to zero would be easiest right now. So once i set it to zero... it has no control over my tuning on the ecu besides vtec engagement correct? Like in the previous post it'll just be a fancy gauge that lights up
Old Sep 21, 2004 | 06:18 PM
Enrikez's Avatar
yes, did the same thing with my field vtec controller..it was f**king with my MAP sensor so i just disconected it from the map and am just using it for vtec engaement. no prob.
Old Sep 21, 2004 | 06:44 PM
mrbsponge's Avatar
i have uberdata and still have my vafc hooked up, i never got a chance to tune it at all so i had to make some correections with the vafc, it still works fine and i make over 300 on boost so im not too worried.
you just have to watch out, if you take away a bunch of fuel it adds timing and when you add a bunch of fuel it drops timing,, so its not too bad
95BoostedEJ1
Engine Management and Tuning
Feb 23, 2009 09:47 PM
IgniteTeg
May 1, 2002 03:57 AM
IgniteTeg
May 1, 2002 03:13 AM
