main relay problems after a walbro install?
Old Sep 19, 2004 | 12:40 PM
SOHC_MShue's Avatar
Default main relay problems after a walbro install?
now that I installed a walbro 255 my fuel pump doesnt come on all the time, does this pump put more stress on the main relay?
I had main relay problems when my car was stock and it was hot outside, so i should replace it anyways, but has anyone had this problem?
Old Sep 19, 2004 | 01:56 PM
sleeping GIANT's Avatar
I had the same situation , stock pump, when it was hot my fuel pump would not prime. so I put a new main relay in, no fix, put a new walbro 255lph pump in ,no fix. eventually it would not prime hot or cold. checked for voltage coming out of the ecu and thats what it was, the ecu was slowly crapping out on me. not trying to scare you but it sounds like my situation dude.
Old Sep 19, 2004 | 05:42 PM
Bailhatch's Avatar
Default Re: (sleeping GIANT)
maybe the ground on the thermostat housing is bunk
Old Sep 20, 2004 | 07:08 AM
yusoslo's Avatar
Default Re: (Bailhatch)
where is the ground on the thermostat housing?
yusoslo's Avatar
Default Re: (yusoslo)
plus it is the main relay, becuase on the 92 civic it was always a problem, there was not enough room in the relay to dissipate heat and they became heat soaked
3easy21
Jun 11, 2012 07:27 PM
B18c1turboedEK
May 19, 2009 09:17 AM
Got_EF8
Sep 24, 2008 10:38 PM
nonbox
Jan 30, 2006 01:00 PM
Steve
Aug 29, 2001 06:38 PM
