What Spring
Old Sep 21, 2004 | 02:33 PM
Lucky_Smurf's Avatar
Default What Spring
Hey question for you all. I'm buying a Tial 44mm and i'm wondering what spring to order. I plan on running around 28-30 psi at the track but I want to be able to daily on a pretty low boost setting 8-10 psi. My setup is b18c 84mm with a t3/t67 turbo.
Old Sep 21, 2004 | 03:51 PM
EkMeg99's Avatar
Default Re: What Spring (Lucky_Smurf)
An 8-10 lb spring would be your best bet, that way you can run off the wastegate for daily driving.
Old Sep 21, 2004 | 05:56 PM
whackassfawker's Avatar
I can't imagine that a 8psi spring hold be able to control anything over 20psi very well.
Old Sep 21, 2004 | 05:59 PM
94dxt's Avatar
Default Re: (whackassfawker)
I beleve they have a 12 psi or so spring. You'd want a spring as close to your target psi as possible.
Old Sep 22, 2004 | 12:04 AM
Default Re: (94dxt)
I had heard I should get a 1 bar spring. That would supposedly give me what I needed for the high boost but still be somewhat streetable. I would like to be able to turn the boost down even more but I guess I'll just man up and live with it.
Old Sep 22, 2004 | 03:14 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (Lucky_Smurf)
you can only go 3 times higher than the wastegate spring , meaning if you have a 10psi spring , your max boost will be 30 psi.
Old Sep 22, 2004 | 06:31 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">you can only go 3 times higher than the wastegate spring , meaning if you have a 10psi spring , your max boost will be 30 psi.</TD></TR></TABLE>
Unfortunately that is not a fact I have seen it only double a few times and would GUESS that that is a more accurate assumption rather than triple
I would go 1 bar If you have Lower Comp you will want alittle more boost anyway, you will see
ctownintegra
Jul 9, 2008 02:41 AM
high_octane
Oct 12, 2007 02:58 AM
tagperformance
Jun 29, 2007 03:33 PM
9deuce9rr
Mar 28, 2004 12:32 PM
Short Round
Nov 12, 2003 10:16 PM
