which is the biggest injectors i can run without a resistor box?
I've quit using this account
i have a 94 civic.
turbo d16z6, p28 soon to be uberdata chipped.
my question is,
i thought 440 were the biggest?, but i had heard some one had 550 that i could use.
what is the max whp for 440's?
i plan on ordering them today, so any info would be great.
thanks
kelly
my question is,
thanks
kelly
Re: which is the biggest injectors i can run without a resistor box? (llewsirc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llewsirc »</TD></TR><TR><TD CLASS="quote">i have a 94 civic.
my question is,
thanks
kelly</TD></TR></TABLE>
the biggest injector that you can run withour resistor is the 780cc from RC they are costly at 299 a set but they are saturated and do work fine. Talk to ben@importparts.com if you need them he has plenty over there.
my question is,
thanks
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">i thought resistor boxes are required for a specific fuel injector type, not the actual size of the injector.
Modified by igo4bmx at 10:51 AM 9/21/2004</TD></TR></TABLE>
i thought they didnt make a injectors (which ever one you dont need a resistor box to run) above 440/550?
Re: (llewsirc)
Nope, they have 750cc Saturated ones now (you only need a resistor box for Peak and hold injectors) - https://honda-tech.com/zerothread?id=918428
Re: (llewsirc)
you are thinking of the dsm 450cc and 440cc injectors. They are peak and hold injectors which require you to wire in a resistor box. Honestly I think wiring in the resistor box is definantely better than spending over $200 on rc injectors if you only need 440 or 450cc injectors. The resistor box really isn't hard to wire either.
These are the largest saturated injectors currently available:
http://www.importparts.com/sho...=4480
http://www.importparts.com/sho...=4481
Also make sure you order some wire clips if you are OBD-2.
Re: (llewsirc)
Correct me if I'm wrong, but on the import parts web sit for the injectors it said 94+ accords. My 99" accord has high imp. injectors factory (13-15 ohms). The injectors you showed were low imp. wouldn't you have to use resistors or a resistor box for them to work correctly? By the way I"m getting ready to install 780cc percision injectors which are low imp. thanks
Re: (Turbowa)
Yea you will require a resistor box to run low resistance injectors in your 99 Accord. But the 650cc and 750cc injectors I listed are high resistance (saturated) injectors.
