LS pr0ject, yup another one...
Old Oct 24, 2004 | 08:02 AM
22boost's Avatar
Default LS pr0ject, yup another one...
project over the winter/spring is ls turbo, done a lot of research and still am for the setup and what others have done. so heres the setup, tell me what you think and pro/cons of parts. my goal is 300-350hp, but id like to keep the torque strong too...management will be Greddy Emanage.
Block:
b18a1, H-beam rods w/arp rod bolts, JE SRP Pistons std. bore 9.2:1 w/ moly file-fit rings.
Head:
Dh-Racing Ported LS head.
Includes: Race Port and Polish
Dual Valve Springs
Titanium Retainers
Dh-Racing Valves
3 Angle Valve Job
Diamond Milling/Resurfacing
Glass Beaded Combustion Chambers
Glass Beaded Head (Entire Head)
Line Honed Cam Journals
Hot Tanking/Degreasing
Skunk2 I/M
Big bore T/B
Turbo:
Basically a DRAG kit but with Tial w/g
Walboro 255lph intank fuel pump
TurboSmart dual stage boost controller.
Questons:
What size TB?
Will stock sleves hold?
What size injectors?
Clutch options?...
Stock Axles w/ 'easy' shifting?
Where can I expect to be boosting at to reach my hp goal?
Old Oct 24, 2004 | 09:02 AM
StolenTeg's Avatar
Default Re: LS pr0ject, yup another one... (93dxkid)
Everything sound nice, I dont know a lot about the E-manage but i know it still a piggy back. It allow tuning but i dont think it have all the feature all the other Stand Alone have, So i think you should look into a Stand Alone system. I think some 7XXcc injector should be good enough for the power you plan on making.
Old Oct 24, 2004 | 09:11 AM
silverb18's Avatar
Default Re: LS pr0ject, yup another one... (StolenTeg)
I like what you are thinking of doing with your block. If your goals are 300-350 whp, you'll need to do it to run that power daily/reliably. I really think you'd be wasteing your time putting all that money into the head because you can make over 300 hp easy on an ls with the stock head. If anything, look into getting a vtec tranny if you really want to spend money.
The drag kit is ok, but you could do better, especially with the manifold. Look into piecing a kit together yourself. I would also ditch the greddy e-manage and go with hondata, much better software. Find a good stage III clutch and you should be fine.
Old Oct 24, 2004 | 12:43 PM
22boost's Avatar
Thanks, and keep the posts coming. Im debating having dh-racing put the dual valve springs/retainers in with the package. You can actually pick up that head package from them for about $600bucks. Their head interests me because it will be fresh and not have the XXXXXXmiles my ls has. Also with the port/polish work I was hoping to free up the poor stock flow and allow me to hopefully run less boost. but make more power with the head.
management im still debating on. hondata sound really great but ill also be looking forward to converting to obd1, from obd0. ill have to search for a clear word for word step by step tutorial for the conversion if i go hondata. yes the car will be a daily driver. also i forgot to mention, arp headbolts etc. in the setup. Ive read that yes the drag maifold isn't the greatest because of wastegate location, but its something i will upgrade after everything is running smoothly.
anymore opinions/options?
Old Oct 24, 2004 | 01:56 PM
JDMs1eeper's Avatar
sounds really good. with the right setup you can easily make 300whp on 10psi so you should make 350 easily with that setup and still be very reliable. good luck
Old Oct 24, 2004 | 07:12 PM
22boost's Avatar
Default Re: LS pr0ject, yup another one... (JDM S1eeper)
bump for more
Old Oct 24, 2004 | 08:32 PM
silverb18's Avatar
dude just read what I said or search more.....
VTECLsTurboTeg
Dec 15, 2009 09:31 PM
jdmb16turbo
May 13, 2009 07:00 PM
b20vtechatch
Apr 9, 2006 06:14 AM
00b18b
12
May 30, 2004 05:25 PM
BlowOff
Mar 14, 2002 12:24 PM
