Turbo hitting radiator...
Old Oct 25, 2004 | 12:19 PM
MooreBoost's Avatar
Default Turbo hitting radiator...
How bad is it that my compressor housing is hitting my radiator?
Old Oct 25, 2004 | 12:40 PM
lanojp1's Avatar
Default Re: Turbo hitting radiator... (tegunderpressure)
its normal, you should have switched to a half size radiator either aftermarket or del sol vtec dual core...im in the process of ordering one for my setup soon...
Old Oct 25, 2004 | 01:03 PM
MooreBoost's Avatar
Default Re: Turbo hitting radiator... (lanojp1)
I know, but I read all the **** you have to do to mount one, and it seems like a less than pleseant job.
Old Oct 25, 2004 | 02:22 PM
Finland's Avatar
I fabbed up some new top brackets that tilt the top of the radiator towards the front of the car, it will give you over 1/2" of clearance easily.
Old Oct 25, 2004 | 03:03 PM
Turbo E's Avatar
meke the hole of the rad mount longer so you can tilt the rad foward. u can gain almost 1/2" best of all its free
Old Oct 25, 2004 | 03:07 PM
G
sh!t happens.
Default Re: (Turbo E 604)
My turbo is touching my PWR half stack radiator. It is touching were the were the coupler from the turbo is. Its hasnt hurt it so far. Is all i have to do is clock the turbo some more and it will not touch it but that is alot of work. .. What manifold are you running?
97dc2
Jan 1, 2006 10:03 PM
Vinhtran17
Aug 30, 2004 07:56 PM
BoOsTiN Dc2
May 23, 2004 04:43 PM
b16hybridsol
Feb 11, 2004 03:43 PM
