Should I NOS it?
Old Oct 25, 2004 | 05:48 AM
unix4linux's Avatar
Default Should I NOS it?
Hey wassup everyone,
I wanted to know if you guys think it's safe to NOS my car the way it is now. Here is what I have.
1994 LS
1.7 gsr bottom with si pistons
stock rods from 1.7 gsr
spoon head gaskette
arp head studs
type r cams and valvetrain
msd 6al
P28 ecu chipped with skunk2
stage 3 clutch CM
Apexi full exhaust
Would it be ok to throw in an NOS wet system direct port into the car? 100 shot?
Let me know what you guys think...or should I throw in a smaller shot?...if yes then great...if not then why and what should i do first?
Thanks in advance
Old Oct 25, 2004 | 06:53 AM
beepy's Avatar
Default Re: Should I NOS it? (unix4linux)
NOS in not an adjective.
Old Oct 25, 2004 | 07:41 AM
unix4linux's Avatar
Default Re: Should I NOS it? (beepy)
Does that answer my question...lol
Old Oct 25, 2004 | 08:53 AM
DC2Slow's Avatar
u need to upgrade ur fuel system to compensate for n2o...
Old Oct 25, 2004 | 09:07 AM
MooreBoost's Avatar
Default Re: Should I NOS it? (DC2Slow)
Your compression ratio is probably pretty high, and the Skunk2 program is going to advance your timing. I would get rid of the skunk2 program all together, and run a 50 shot wet, depending on your C/R.
unix4linux's Avatar
what shoud i do to the fuel system?...will fuel pump and injectors do it? apexi hack?
Old Oct 25, 2004 | 09:11 AM
unix4linux's Avatar
Default Re: Should I NOS it? (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Your compression ratio is probably pretty high, and the Skunk2 program is going to advance your timing. I would get rid of the skunk2 program all together, and run a 50 shot wet, depending on your C/R.</TD></TR></TABLE>
yeah its about 11:2.0 . I was running 11:0 before the spoon gaskette. So go with 50 shot and not 100? I thought keeping the skunk2 would be good...I have seen a lot of people running the skunk2 on a bit higher compression than I...but I just want to be sure
Old Oct 25, 2004 | 09:27 AM
MooreBoost's Avatar
Sure, high C/R and Skunk2 were meant for eachother. Theyre both used in allmotor applications, but will hinder you when going the forced induction route.
Old Oct 25, 2004 | 09:30 AM
Zakar's Avatar
a new fuel pump and a 75 dry shot and you'll be happy
Old Oct 25, 2004 | 09:42 AM
unix4linux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Sure, high C/R and Skunk2 were meant for eachother. Theyre both used in allmotor applications, but will hinder you when going the forced induction route. </TD></TR></TABLE>
ok..I will look into it...i'll see how much of a shot I can run with my setup then...thanks for the info...any other ideas are welcomed
Old Oct 25, 2004 | 09:49 AM
MooreBoost's Avatar
If you are going to run it on your current setup you NEED to have it on a dyno when you spray, you will have to watch for detonation very closely.
Old Oct 25, 2004 | 12:03 PM
unix4linux's Avatar
ok...i'll definately dyno...but question..why should i dyno if i don't have a standalone system...there won't be much they can do except to tell me that i might blow up if i don't get a standalone to tune my weak point of detonation right?...correct me if i am wrong
Old Oct 25, 2004 | 01:09 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unix4linux &raquo;</TD></TR><TR><TD CLASS="quote">what shoud i do to the fuel system?...will fuel pump and injectors do it? apexi hack?</TD></TR></TABLE>
Not trying to be rude here but you might want to do a bit more reading on how nitrous works and what different things are called..
Old Oct 25, 2004 | 02:07 PM
unix4linux's Avatar
Default Re: Should I NOS it? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Not trying to be rude here but you might want to do a bit more reading on how nitrous works and what different things are called..</TD></TR></TABLE>
no offense taken...i am new to forced induction so i could definately use all the help...thanks
Old Oct 25, 2004 | 02:13 PM
Killer_B's Avatar
100shot will be fine as long as the motor is healthy. i would definitely go with a wet kit and a Walbro pump. other than that, i would get colder plugs and retard the timing accordingly.
Old Oct 25, 2004 | 02:43 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unix4linux &raquo;</TD></TR><TR><TD CLASS="quote">ok...i'll definately dyno...but question..why should i dyno if i don't have a standalone system...there won't be much they can do except to tell me that i might blow up if i don't get a standalone to tune my weak point of detonation right?...correct me if i am wrong</TD></TR></TABLE>
You do not need a standalone to tune your motor. You can tune the nitrous jets, your timing, as well as fuel pressure if you just buy a B&M regulator.
Old Oct 25, 2004 | 05:37 PM
unix4linux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">You do not need a standalone to tune your motor. You can tune the nitrous jets, your timing, as well as fuel pressure if you just buy a B&M regulator.</TD></TR></TABLE>
ahh ok this is good...i'll get me a fuel pressure regulator that can be adjusted...should I go with the vortech fmu instead of the regulator or just regulator or perhaps both?...how about injectors?..could the injectors remain the same (stock) if i get a regulator and pump?
you guys have been great
Old Oct 25, 2004 | 05:49 PM
MooreBoost's Avatar
An FMU is used for boosted applications, you don't want that. Just get the regular FPR, and a pump. Your stock injectors will be fine.
Old Oct 25, 2004 | 05:50 PM
unix4linux's Avatar
thanks tegund....will def. do...
PacoEJ
Feb 10, 2011 06:34 AM
oianarchy
Dec 11, 2006 07:09 AM
waxbunny
Aug 2, 2005 04:48 AM
Simple
May 2, 2003 01:29 PM
I Like Boost
Jul 3, 2002 03:23 PM
