ignition timing?
Old Oct 27, 2004 | 08:45 PM
CRXLST's Avatar
Default ignition timing?
How much can you retard your timing by sliding the distributor all the way back? I have heard 3 degrees and I have heard 5 degrees. Does any1 know for sure???
Old Oct 27, 2004 | 08:54 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: ignition timing? (CRXLST)
The best thing to do is have your car timed with a timing gun. Just moving the distributor forward or backwards will not make the car run to its full potential.
Old Oct 27, 2004 | 08:56 PM
CRXLST's Avatar
Default Re: ignition timing? (NVturbo)
I am wondering because I don t want to overboost. lol No retard + boost = boom!
Old Oct 27, 2004 | 09:21 PM
CRXLST's Avatar
bumps?
InTeGrA B18b1's Avatar
bring back either .5 per lb or 1. my is 1 per lb of boost which is very conservative and safe.
Old Oct 27, 2004 | 09:27 PM
CRXLST's Avatar
Default Re: ignition timing? (InTeGrA B18b1)
I would need a BTM or something to retard my timing per pound of boost... I just wanna know how much I can retard my timing by sliding the distibutor so I can run 8psi and not detonate...
shermanyang's Avatar
what engine management are you using? if you're only running 8psi intercooled...i wouldn't worry too much. just as long as you've got good gas you'll be fine. but if it for a piece of mind then i'd go .5* per lb of boost.
Old Oct 27, 2004 | 09:30 PM
SOHC_MShue's Avatar
1degree per psi is a lot of retard. You don't need it retarded that much.
Old Oct 27, 2004 | 09:31 PM
CRXLST's Avatar
Default Re: ignition timing? (shermanyang)
Not using EMS... Yes it is intercooled and I always run 93 even on all motor. So if I slide my distributor a lil I should B fine???
Old Oct 27, 2004 | 09:35 PM
make sure you using a timing gun and pull the distributor towards you...not the firewall. i would even say it would be safe to do 1* per 2 lbs of boost.
Old Oct 27, 2004 | 09:40 PM
CRXLST's Avatar
Ok... By turning your distibutor it doesn t retard your timing per pound of boost. That is what BTM is for. I just want to run 8psi then 10psi. I need to know if I slide my distibutor will it be enough of a retard for that much boost.
Old Oct 27, 2004 | 09:44 PM
SOHC_MShue's Avatar
do you have a btm?
Old Oct 27, 2004 | 09:45 PM
CRXLST's Avatar
Default Re: ignition timing? (SOHC_MShue)
If I had a BTM I wouldn t need to know if I could move my distibutor to retard my timing enough for 8psi....
xcountrirunr
Dec 1, 2004 08:57 AM
B_1_8_hatch
Jul 28, 2003 01:33 PM
madman604
May 9, 2003 05:57 PM
rudebwoy
Mar 29, 2003 08:55 AM
808eg6
Jun 24, 2002 07:52 AM
