where to T for boost gauge
Old Oct 26, 2004 | 09:41 PM
hatchback_al's Avatar
Default where to T for boost gauge
hey guys, i hooked up my boost gauge and cant get it to show any boost. My car IS boosting I can feel it no doubt, but the gauge just isnt showing anything at all. Right now I have the line T-d to a vacuum hose on the rear of the intake manifold (d16y8). The nipple is on the drivers side near the bottom on the back of the intake plenum if that makes any difference. What could the problem be?
Old Oct 26, 2004 | 09:46 PM
donkiman's Avatar
Default Re: where to T for boost gauge (hatchback_al)
could be a defective gauge, drilling and tapping its own hole would help also, or also make sure that the hose is still connected because unless its really on there tight they love to blow off.
Old Oct 26, 2004 | 09:51 PM
Default Re: where to T for boost gauge (donkiman)
a more ideas bump
Old Oct 27, 2004 | 06:00 AM
93turbo16's Avatar
did you put nylon tape around the fittings of the boost gauge? If not that could be one problem, the other could be a pinch line somehwere.
Old Oct 27, 2004 | 10:56 AM
Default Re: (93turbo16)
I checked the line, went through and teflon tape all parts of it. I ran the car with the line unhooked from the back of the gauge and can feel suction through the line. This leads me to believe the gauge itself is bad.
Old Oct 27, 2004 | 02:20 PM
djwest24's Avatar
Default Re: (hatchback_al)
maybe it is....but try tapping between the manifold and the fpr.
Old Oct 27, 2004 | 02:58 PM
91civicDXdude's Avatar
Default Re: (quicksilver17981)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver17981 &raquo;</TD></TR><TR><TD CLASS="quote">maybe it is....but try tapping between the manifold and the fpr.</TD></TR></TABLE>
dont tap the FPR line. It can cause a weaker than normal vacuum going to the FPR, and that in turn will cause the car to run rich at idle.
Old Oct 27, 2004 | 03:27 PM
PrettyLude's Avatar
do you have the vacuum line connected with the grommet to hold it in place behind the gauge?
Old Oct 27, 2004 | 07:22 PM
Default Re: (PrettyLude)
What grommit is this you speak of? I have a nylon line that goes through the part that threads onto the nipple on the back of the gauge. On the line is this little cone shaped deal that the line runs through. I believe that little guy seals the line between the 2 threaded parts (on on the line, and the nipple on the back of the gauge). I have these connections on both ends of the boost line.
Old Oct 28, 2004 | 03:58 PM
djwest24's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">
dont tap the FPR line. It can cause a weaker than normal vacuum going to the FPR, and that in turn will cause the car to run rich at idle.</TD></TR></TABLE>
but once the system is closed, i dont see how it'll be affected.
Old Oct 28, 2004 | 05:42 PM
TwoPointZero's Avatar
Banned
Do the VAC and BOOST test on the gauge. Disconnect the vacuum hose and suck and blow on it to see if the needle fluctuates.
Old Oct 28, 2004 | 09:36 PM
Default Re: (TwoPointZero)
i blew and sucked as hard as i could on the hose before i installed it, didnt move one iota. I figured i just couldnt blow hard enough
Old Oct 28, 2004 | 09:53 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al &raquo;</TD></TR><TR><TD CLASS="quote">i blew and sucked as hard as i could on the hose before i installed it, didnt move one iota. I figured i just couldnt blow hard enough</TD></TR></TABLE>
It should of moved at the most 1 lb ... if not.. thats your problem.
Old Oct 29, 2004 | 10:04 AM
ok well I ordered a new gauge we will see what she does
boostdB16a
Jul 28, 2003 11:48 AM
B18EG6
Aug 7, 2002 12:31 PM
LOwrestling2001
May 19, 2002 09:35 PM
Guitarzann
Dec 18, 2001 09:56 AM
falcongsr
Jul 3, 2001 03:14 PM
