building my h22
Old Oct 27, 2004 | 09:43 AM
boosted lude's Avatar
Default building my h22
i want to build my bottom end and i need to know exactly each part i will need to do so... and also do you guys know of any sites where i can get good prices... my plans are to run about 8psi daily and go up to about 15-17psi at the track... i do know that the h22 has to be sleeved first, but can you just buy sleeves or do you have to ship the block out to get it sleeved?
Old Oct 28, 2004 | 06:52 AM
PrettyLude's Avatar
hit up earl and get some good prices from him, and get your sleeves thru him too
Old Oct 28, 2004 | 07:43 AM
honda13typer's Avatar
Default Re: (PrettyLude)
you can buy the sleeves first and then have a machine shop install them but the problem is finding a local machine that you trust. otherewise you have to send it out to a more reputable machine shop...
Old Oct 28, 2004 | 07:45 AM
Default Re: (honda13typer)
i would recomend: lc pistons, rods, sleeves, head studs, head gasket.... then ur set on the bottom end...
Old Oct 28, 2004 | 09:05 AM
b16hybridsol's Avatar
Default Re: building my h22 (boosted lude)
you should just take it to a local shop and let them deal with it so you don;t risk cheaping out on a key part or parts. there is a lot of research invovled in this
Old Oct 28, 2004 | 12:26 PM
tunedbylorange.com's Avatar
pistons, rods, all new bearings, sleeves, micropolish crank, balance and blue print bottom end, all new bottom end gaskets, head gasket, head studs & main studs
I think that's it
Old Oct 28, 2004 | 01:18 PM
thanks for all the replies... how can i contact earl
Old Oct 28, 2004 | 01:31 PM
david_rg79's Avatar
i would reccomend if you dont know what you need, then you probably should have a shop do it for you...not to be mean but it may be cheaper in the long run
anyways...we boosted my friends h22 18psi for years b4 he was going 9500rpms(stock motor) in 3rd and hit 2nd...lol damn accord trans
he was on a 50trim and propane inection...h22 is closed deck so no worries of sleves moving...as long as you dont detonate stock bottom end is just fine
Old Oct 28, 2004 | 01:59 PM
H22CB7's Avatar
micropolishing the crank isn't needed though IMO.
Old Oct 28, 2004 | 04:30 PM
da_rimrocka's Avatar
Default Re: (H22CB7)
you can find earl here
https://honda-tech.com/zero...94999
get in touch with him by PM or just call him up. he is very helpful and has awesome prices on stuff.
Old Jan 4, 2005 | 08:06 PM
. o 69 o .'s Avatar
Default Re: (shurick)
what kinda of top end work should be done once you build up a bottom end??
sshh
May 21, 2013 02:25 PM
turboD_EG
Nov 19, 2008 05:59 AM
h22a193
Nov 13, 2005 12:23 PM
ThE PiMpiN Co
Sep 16, 2005 09:00 AM
djnikko
Sep 22, 2004 07:13 AM
