vortech fmu help quick
Old Oct 26, 2004 | 05:42 PM
syiracing's Avatar
Default vortech fmu help quick
what ratio disk do i need for a d16a6 11 lbs of boost and stock injectors
Old Oct 26, 2004 | 06:23 PM
95turboex's Avatar
Default Re: vortech fmu help quick (syiracing)
I think the 12:1 is the highest you can get buy you would more than likely be pushing the limits of your stock injectors if you dont pass that point. I believe that the stock ones max out somewhere around 8 or 9 psi with a 12:1
Old Oct 26, 2004 | 06:30 PM
syiracing's Avatar
Default Re: vortech fmu help quick (95turboex)
the only reason i am using stock injector is because i have to race this weekend and i dont have time to wire up injectors( i only plan on running 6lbs of boost this weekend).is 12:1 the best ratio to go with?
Old Oct 26, 2004 | 06:34 PM
boosted-delslow's Avatar
I think the 12:1 disk should be good. But my personal opinion is no matter what disk you put in there it is still gonna do the same thing.
Old Oct 26, 2004 | 06:43 PM
syiracing's Avatar
Default Re: vortech fmu help quick (boosted-delslow)
really?the disks change the amount of fuel pressure added to the fuel system per lb of boost
japspecb7
Jul 22, 2008 04:59 PM
Rah Rah
Feb 24, 2003 06:03 PM
Giuseppe
Oct 10, 2001 09:23 PM
Tr0LL
Sep 14, 2001 10:54 PM
not so civic
Aug 7, 2001 04:10 AM
