z6 pistons in y8 motor, same compression. ??
Old Oct 25, 2004 | 02:19 PM
platinum00's Avatar
Default z6 pistons in y8 motor, same compression. ??
I have a set of 8.5.1 comp pistons for a d16z6, if i put those in a d16y8. is it still the same compression.
for some reason i thought the stroke was a little different on a y8 motor.
any input..
thanks
platinum.
Old Oct 25, 2004 | 06:03 PM
platinum00's Avatar
Default Re: z6 pistons in y8 motor, same compression. ?? (platinum00)
bump
Old Oct 25, 2004 | 06:11 PM
JRciv's Avatar
I could answer your question, but I'll just give you the link to this ultra-useful website:
http://www.knology.net/~jediklc/D.htm
Old Oct 25, 2004 | 08:05 PM
platinum00's Avatar
Default Re: z6 pistons in y8 motor, same compression. ?? (JRciv)
if i messed around with the site correctly, it looks like it will increase the compression of the piston due to the difference in the heads.
about 1/2 point.
and on srp's site the y8 pistons are 9.0.1,
wonder if it's the same piston
platinum.
Old Oct 25, 2004 | 08:55 PM
willyboyK20's Avatar
yeah the y8 head has smaller quench areas than the z6 head thereby making the comp. higher
dravesef
11
Nov 12, 2007 05:25 PM
99hatch
Feb 1, 2005 08:36 AM
pip9
Jul 12, 2004 05:10 PM
ill_take_one
Feb 25, 2003 12:05 PM
Ash J. Williams
Oct 3, 2002 10:56 AM
