JRSC help!
Old Oct 23, 2004 | 06:50 PM
Tad's Avatar
Tad
Default JRSC help!
The directions mention a "pressure switch" that i'm supposed
to install in the "1/8th NPT hole" on the back of the supercharger intake mani.
The pressure switch is something that was supposed to have been supplied
by JR, but I got a used kit and apparently its not included.
wtf does this do? And can I get by without it for a few days?
thanks!
Old Oct 23, 2004 | 08:06 PM
Tad's Avatar
Tad
doesnt anyone know??
btw, the instructions dont mention anything about swapping my crank.. yet i have a JR crank with my kit? Is that the 8psi upgrade crank I got, and i'll get 6psi with the stock crank? or what?
THHaahhhNNNKS!
Old Oct 23, 2004 | 08:14 PM
norcalcrx's Avatar
Default Re: (Tad)
Ok the pressure switch is usually on the top/back side of the jrsc manifold. It will be black and have a screw on it. You will need to use the pulley that comes with the jrsc kit. It is different then your stock pulley and allows for the alt to be routed on the sc belt. Did your kit come with instructions? If not you can dl them from jrsc website.
Old Oct 23, 2004 | 08:33 PM
Tad's Avatar
Tad
hmm, well i've got one empty hole on the back of the mani.
its a thick(looks like 14mm) threaded hole, and 2 smaller ones on each side of that.
i'm guessing thats where the switch goes.
Any clue what the switch does?
Old Oct 23, 2004 | 08:43 PM
norcalcrx's Avatar
Default Re: (Tad)
What motor is the jrsc for?
Old Oct 23, 2004 | 08:50 PM
Tad's Avatar
Tad
Default Re: (norcalcrx)
pm'd back!
Old Oct 24, 2004 | 12:35 AM
Tad's Avatar
Tad
ok,
thanks to norcalcrx,
I guess I do really need this.
and i'll be hunting it down now.
Anyone know wtf it really does though?
I found in the instructions that it connects to the "JR fuel enrichment relay"
and a good bit of hacking of your wiring is done to hook that relay up.
anyone know wtf all this is for?
(i dont like blindly installing stuff, even if it did come with a prefabbed kit).
Riptide101
Oct 4, 2017 08:26 AM
PrinceBlueCat
Feb 1, 2010 02:11 AM
ty521825
Jun 18, 2009 12:22 AM
MADEINIRAQ
Nov 21, 2003 05:24 AM
