whats more worth it, what would you do, pick one, etc.
ls + sleeves, rods, pistons & pieced together turbo kit
z6 + sleeves, rods, pistons & pieced together turbo kit
-both are about the same price... correct? (assuming i use the ls trans)
-goal is 250 daily driven hp, dead f-ing reliable.
Re: whats more worth it, what would you do, pick one, etc. (jbell)
If your going to sleeve a block, sleeve the b series so you can deck it, bore it, stroke it, add a vtec head... anything you ever want to do if you run into money/a want for more power that you do not see ahead of you.
i'd do the ls. but actually if it was really up to me id just daily boost the ls stock with a good tune. if u wanna be safe u could upgrade pistons and rods but the ls has pretty thick walls as it is. I dont see u needing sleeves for a reliable 250whp on that block.
Re: whats more worth it, what would you do, pick one, etc. (Sp00n'd Supra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n’d Supra »</TD></TR><TR><TD CLASS="quote">b seires has better/strong tranny</TD></TR></TABLE>
i was under the impression the z6 trans had better gearing than the ls.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell »</TD></TR><TR><TD CLASS="quote">i was under the impression the z6 trans had better gearing than the ls. </TD></TR></TABLE>
i meant in general, all the options avaliable to you
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">LS is better geared...Z6 seems like it is better geared because it redlines higher, but the actual gear ratios are shorter in the LS.
Go for the LS </TD></TR></TABLE>
i thought it was the other way around. can anyone confirm this?
Re: (BauleyCivic)
The LS is definitely the way to go but are you sure the LS gears are better? I'm going to challenge you to find the ratios for that.
Re: (D15B7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15B7turbo »</TD></TR><TR><TD CLASS="quote">The LS is definitely the way to go but are you sure the LS gears are better? I'm going to challenge you to find the ratios for that. </TD></TR></TABLE>
i looked around, no luck
Re: (jbell)
If you want 250 solid reliable HP WTF are you sleeving it with pistons and rods? I ran 280 WHP on a B16 with stock pistons and rods, some ARP's, and hondata. Daily drove it for over a year with the turbo, and it saw lots of abuse with a vorturd blower before that.
Re: (b16coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe »</TD></TR><TR><TD CLASS="quote">If you want 250 solid reliable HP WTF are you sleeving it with pistons and rods? I ran 280 WHP on a B16 with stock pistons and rods, some ARP's, and hondata. Daily drove it for over a year with the turbo, and it saw lots of abuse with a vorturd blower before that.</TD></TR></TABLE>
because the rods and pistons are like insurance. i dont need to sleeve. thats a step too far.
i'd like to turbo a b16 or gsr, but thats too expensive.
Re: (jbell)
ls
3.23
1.90
1.27
0.96
0.71
4.266
d16
3.250
1.900
1.250
0.909
0.750
4.250
looks like they are pretty much the same.
on 22.8inch tires, at 9500 rpms here are their speeds:
d16
46.9
80.3
122
167.8
203.3
ls
47
80
120
157
212
and to show you how bad that is,
itr
42.7
62.5
79.6
100.5
127.3
3.23
1.90
1.27
0.96
0.71
4.266
d16
3.250
1.900
1.250
0.909
0.750
4.250
d16
46.9
80.3
122
167.8
203.3
ls
47
80
120
157
212
itr
42.7
62.5
79.6
100.5
127.3
Re: (jbell)
Holy ****, 120 in 3rd gear.
In the orignal post you said you were going to sleeve it.
Then you said<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell »</TD></TR><TR><TD CLASS="quote">
i'd like to turbo a b16 or gsr, but thats too expensive. </TD></TR></TABLE>
Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">Holy ****, 120 in 3rd gear.
Then you said
??</TD></TR></TABLE>
thats at 9500 rmp.
i decided that sleeving it just too much, and not needed.
thats at 9500 rmp.
Dc4turbo408
01-30-2005 03:38 PM
