Which would benefit my setup more?
Old Oct 25, 2004 | 03:55 PM
MooreBoost's Avatar
Default Which would benefit my setup more?
I currently have a CCA FMIC with rewelded entanks so they look like this-
I have been told having them like that will cause more lag, and I will be running a fairly large turbo, so that will be an issue to begin with. I would like to counter the lag one of two ways-
1) Get a new FMIC and leave the endtanks how they come, resulting in better flow, and less lag.
2) Get a nitrous kit, and run a small shot to help spool the turbo.
This is for a drag CRX that is only driven to the strip and back. Thanks.
Old Oct 25, 2004 | 04:46 PM
.nate's Avatar
Why not air-to-water in a drag car?
Old Oct 25, 2004 | 04:49 PM
MooreBoost's Avatar
Default Re: (.nate)
lanojp1's Avatar
what turbo?
Old Oct 25, 2004 | 05:07 PM
MooreBoost's Avatar
Default Re: (lanojp1)
T3/T04e 50 trim .48 A/R .60 A/R
My tuner is telling me neither will be required.
Old Oct 25, 2004 | 05:17 PM
Adriano's Avatar
Default Re: (tegunderpressure)
the lag shoun't be that bad. You are only running a .48 exhaust housing.
Old Oct 25, 2004 | 05:27 PM
lanojp1's Avatar
if its a drag car i wouldnt worry about it..im pushing a bigger turbo on a street car..
Old Oct 25, 2004 | 05:37 PM
adictionbass's Avatar
with the endtanks set up like that you should be running shorter piping too just something else to consider
Old Oct 25, 2004 | 06:51 PM
project dc2's Avatar
Default Re: (adictionbass)
the inlet of the intercooler should be more efficient cuz itll induce the air get an even spread into the core. dunno bout the outlet but shouldnt be too bad.
TurboTeG4
Jan 21, 2006 07:39 PM
dester223
Nov 1, 2004 07:37 PM
B18C1CYA
Oct 10, 2004 06:01 AM
Turbo-Honda
Apr 25, 2004 03:51 AM
