New engine break in
Old Oct 27, 2004 | 12:20 PM
soon2b's Avatar
Default New engine break in
How many times do you have to turn a fresh motor over to build up oil pressure in it. Thanks
Old Oct 27, 2004 | 01:37 PM
m R g S r's Avatar
Default Re: New engine break in (soon2b)
Until it reads on the gauge?
Old Oct 27, 2004 | 01:39 PM
soon2b's Avatar
now that was a genuis answer.....how many does it normally take to read on the gauge. Thanks
Old Oct 27, 2004 | 02:07 PM
djwest24's Avatar
Default Re: (soon2b)
just turn it over for like about 10 secs. u might not see any pressure on the gauge yet, but once u start her up, it should go up in a couple of seconds.
Old Oct 27, 2004 | 02:20 PM
RyanEJ8's Avatar
Default Re: New engine break in (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Until it reads on the gauge?</TD></TR></TABLE>
What if you don't have an oil pressure guage?
I didn't, so I just turned mine over for a good 10-20 seconds.
Old Oct 27, 2004 | 03:50 PM
ATS*Mark's Avatar
OG triple OG
Default Re: New engine break in (RyanCivic2000)
squirt a few drops of oil down the spark plug holes , turn it over for 10 seconds then start her up.
Old Oct 28, 2004 | 07:12 AM
djwest24's Avatar
Default Re: New engine break in (SOHC Turbo *****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC Turbo ***** &raquo;</TD></TR><TR><TD CLASS="quote">squirt a few drops of oil down the spark plug holes.</TD></TR></TABLE>
could you tell me why u do tht?
Old Oct 28, 2004 | 07:33 AM
Muckman's Avatar
Moderator in Chief
I cranked mine over for literally 3+ mins, 30 secs at a time. I never built any oil pressure and didnt even get any oil in the oil filter. I had to start the motor to build oil pressure.
Sometimes cranking isnt enough to prime the oil pump.
Old Oct 28, 2004 | 07:49 AM
honda13typer's Avatar
Default Re: New engine break in (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver17981 &raquo;</TD></TR><TR><TD CLASS="quote">
could you tell me why u do tht?</TD></TR></TABLE>
i beleive you do that because there isnt any oil for the first couple seconds or so. u squirt some oil in there so it has some until the rest of the oil comes...
Old Oct 28, 2004 | 07:50 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
I didn't, so I just turned mine over for a good 10-20 seconds.</TD></TR></TABLE>
I was just being an ***. . .
Old Oct 28, 2004 | 08:01 AM
djwest24's Avatar
Default Re: New engine break in (honda13typer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda13typer &raquo;</TD></TR><TR><TD CLASS="quote">
i beleive you do that because there isnt any oil for the first couple seconds or so. u squirt some oil in there so it has some until the rest of the oil comes...</TD></TR></TABLE>
but if u squirt some thru the spark plug hole, its just gonna sit on top of the pistons, unless u flood it till it flows out, and isnt it bad if u start her up with oil on the pistons? correct me if im wrong.
Old Oct 28, 2004 | 12:53 PM
ATS*Mark's Avatar
OG triple OG
Default Re: New engine break in (quicksilver17981)
it will smoke and burn off.....better than nothin in there .
Old Oct 29, 2004 | 10:34 AM
Muckman's Avatar
Moderator in Chief
Yes but oil isnt normally in the combustion chamber. Its supposed to be under the piston and on the cylinder walls, being scraped down by the piston rings but not in the combustion chamber, that serves no purpose besides fouling your spark plugs.
Assembly lube should be used on all the contact patches of any moving parts.
Old Oct 29, 2004 | 11:26 AM
turbosi03's Avatar
so I should have used lube on the cyl walls? I just lubed it with oil... but its been sitting for a while...
Old Oct 31, 2004 | 09:01 AM
PrettyLude's Avatar
that would be ok, to prevent it from rusting
Old Oct 31, 2004 | 11:40 AM
RyanEJ8's Avatar
Default Re: New engine break in (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">so I should have used lube on the cyl walls? I just lubed it with oil... but its been sitting for a while... </TD></TR></TABLE>
No just oil on the cylinder walls is fine.
hondaz6lx
10
Jan 13, 2007 10:43 AM
555R
Mar 1, 2005 12:11 AM
racingant
16
Jan 23, 2005 10:16 PM
99Sivic
Nov 5, 2004 11:50 AM
