uberdata bin file for t3/t4 turbo
Old Oct 25, 2004 | 07:45 AM
LilCivic04's Avatar
Default uberdata bin file for t3/t4 turbo
i currently am running a d16z6 w/ ob1. i was wondering if anyone is running a t3/t4 turbo, if so i would like to have their bin file so i could use it for my base map.
Old Oct 25, 2004 | 07:55 AM
Kowalski's Avatar
Default Re: uberdata bin file for t3/t4 turbo (LilCivic04)
Why not make your own? Everyone's car is different.
Old Oct 25, 2004 | 08:04 AM
93turbo16's Avatar
Make your own, but look off a good one from uberdata just to make sure you have the idea of things. You always want to make your own, that is the only way you will be sure it is ok. Start by using "the how to make a base map" from keeblers website. Search Uberdata forum to find it.
Old Oct 25, 2004 | 08:11 AM
Joseph Davis's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">You always want to make your own, that is the only way you will be sure it is ok. </TD></TR></TABLE>
No, you always want to tune your basemap, because if you don't it is most definitely NOT okay.
Old Oct 25, 2004 | 11:57 AM
LilCivic04's Avatar
Default Re: (J. Davis)
well i just want somone that has a bin file so i can start tuning it from there. i wasn't going to load it up and just leave it.
Old Oct 25, 2004 | 12:26 PM
93turbo16's Avatar
And I was saying that someone else's basemap might be retartded or send you the wrong one, saying that it is the only way you know it is ok, is saying that you did the map not some one else. Its ok if it runs and its rich, you can most definitley drive it, seeing that its not even close to as bad as the hack....
Old Oct 25, 2004 | 01:48 PM
Default Re: (LilCivic04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 &raquo;</TD></TR><TR><TD CLASS="quote">well i just want somone that has a bin file so i can start tuning it from there. i wasn't going to load it up and just leave it.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Make your own, but look off a good one from uberdata just to make sure you have the idea of things. You always want to make your own, that is the only way you will be sure it is ok. Start by using "the how to make a base map" from keeblers website. Search Uberdata forum to find it.</TD></TR></TABLE>
Reading comprehension, bro...
Old Oct 25, 2004 | 02:21 PM
93turbo16's Avatar
I read that much, I was refering to what you didn't comprehend about what I said earlier.. its cool. Make a basemap and get it tuned, do it yourself, it is a good learning experience. Is that a good answer then?
X2BOARD
Mar 20, 2012 03:51 PM
TylerC161
Oct 25, 2006 07:33 AM
SFlCrx
Oct 4, 2006 10:14 AM
blks2k3
Jul 24, 2006 11:01 AM
big-cat
May 11, 2006 10:49 AM
