Switching injector clips to OBD1. Does wire polarity matter?
H-T White Ops
Just like the title says. I'm switching my OBD2 injector clips over to OBD1s so I can run my RC 550's. Now, does it matter which way the wires get hooked up? Because the OBD1 clips I have came off an old vette and the color wires are yellow /w black stripe - blue, yellow /w black stripe - red, yellow /w black stripe - brown, and yellow /w black stripe - solid yellow. I'm guessing that the yellow with the stripe is either positive or negative on all of them being that that's the only constant color. Does it really matter which way the injectors are wired up?
Thanks.
Thanks.
Re: Switching injector clips to OBD1. Does wire polarity matter? (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">Does it really matter which way the injectors are wired up?</TD></TR></TABLE>
It doesn't matter.
It doesn't matter.
Re: Switching injector clips to OBD1. Does wire polarity matter? (boomslang)
It does matter. .
I had mine reversed and it kept popping an ECU fuse everytimg I turned the key.
So at least it mattered in my case. .
Re: Switching injector clips to OBD1. Does wire polarity matter? (m R g S r)
It depends on the injectors. Some injectors will have one side that is labled "+", most do not care though.
95dc2teg
12-15-2008 08:47 PM
Mr. Vapor
04-27-2005 12:29 PM
BOMBCRU
08-08-2004 02:17 PM
