welding a straight pipe or or use a flex pipe???
Old Oct 25, 2004 | 11:34 AM
B16CRXT's Avatar
Default welding a straight pipe or or use a flex pipe???
Should I just have a straight pipe clamped or welded in place of my cat to the DP or get a flex pipe. Some pro's and cons would be great! What is the real point of having the flex pipe?
TIA!
Old Oct 25, 2004 | 12:12 PM
Frozen E's Avatar
H-T White Ops
if you can go flex pipe go with it. It'll absorb a lot of the vibration and twisting from your engine putting less stress on your DP and exhaust welds/connections.
Old Oct 25, 2004 | 12:20 PM
Stewie's Avatar
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">if you can go flex pipe go with it. It'll absorb a lot of the vibration and twisting from your engine putting less stress on your DP and exhaust welds/connections.</TD></TR></TABLE>
exactly. If you go with a test pipe, you have to have a flex pipe welded in to the dp.
WHat I think you're referring to is flexible exhaust piping not flex pipe. They are two different things.
I don't think the cons of a flexible exhaust piping in place of a test pipe or cat is that big of a deal. You might have to replace it ounce in a while, but it's cheap and easy to do. If you use good clamps, it should make for a leak free setup.
Old Oct 25, 2004 | 12:41 PM
Frozen E's Avatar
H-T White Ops
This is what I picture when I think of flex pipe:
And then there's always this junk which I WASN'T talking about:
Old Oct 25, 2004 | 02:45 PM
B16CRXT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">This is what I picture when I think of flex pipe:
This is what I was speaking of. So It would be best to get the flex pipe and connect it from teh DP to the exhaust?
Would that flexible exhaust piping come in 2.5" so I could use it for a temporary IC pipe? Does it bend enough to make some 45* bends?
Old Oct 25, 2004 | 02:51 PM
Frozen E's Avatar
H-T White Ops
Default Re: (B16CRXT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">This is what I was speaking of. So It would be best to get the flex pipe and connect it from teh DP to the exhaust?
Would that flexible exhaust piping come in 2.5" so I could use it for a temporary IC pipe? Does it bend enough to make some 45* bends?</TD></TR></TABLE>
It comes in 2.5" (that's what I have). You would put that inline with your exhaust, yes sir. Right after the downpipe.
Secondly, you will NOT get this stuff to do a 45* bend. Use that other junk I posted a pic of to do your jerry rigged IC piping if you're that hard up for $$$$.
Old Oct 25, 2004 | 03:04 PM
B16CRXT's Avatar
you read me wrong. lol. I was asking if the FLEXIBLE exhaust pipe can make the 45* bend. haha I know a flex pipe wont. Thanks for the answer though.
I found a place that will custom make a flex pipe for me that has 2.5" on one side and 3" on the other. they didnt give me a quote though
So are there any pros or cons of welding a straight pipe from DP to exhaust other than the stress on welds?
Old Oct 25, 2004 | 03:35 PM
RNPoo7's Avatar
where can you buy that flexible pipe to use as a temp. solution for IC ?
Old Oct 25, 2004 | 04:28 PM
buck02's Avatar
Default Re: (RNPoo7)
we carry any size flex u need
2.5-4.0 inch all best quality stuff
along with pip[ing kits and mufflers
please email me or pm me please
Old Oct 25, 2004 | 05:56 PM
92HB_HB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">......And then there's always this junk which I WASN'T talking about:
...</TD></TR></TABLE>
Actually, i'm using that kind of flex pipe at the moment.. to tell ya the truth, it does the job for me perfectly.. and it was DEFINATELY alot cheaper than those fancy flex pipes.. Just make sure you get it in Stainless Steel so it doesn't Rust/corrode up on ya..
I"ve made 3-4 DP's w/ that kind of flex pipe and i'm happy w/ it for what its purpose is..
Here's one I made last yr for my turbo GSR..
Dont care about the looks much since its gonna get dirty and nasty anyway from the road grime and heat cycles..:
Old Oct 26, 2004 | 02:15 AM
B16CRXT's Avatar
Default Re: (92HB_HB)
So, where can this be located?
Old Oct 26, 2004 | 07:50 AM
RNPoo7's Avatar
I think i found a place to buy it from:
http://www.roadraceengineering...s.htm
Old Oct 26, 2004 | 07:55 AM
RNPoo7's Avatar
I have a question...I need a flex pipe for my downpipe, however, my downpipe is 2.5" and my exhaust is 3". All the flex pipes i found online are only one size. Any idea where to get them with different size on each side?
Old Oct 26, 2004 | 08:04 AM
pbsracerx's Avatar
Here is what my builder did to fix the 2.5" to 3" exhaust conversion.
2.5" downpipe --&gt; Flowmaster 2.5"-3" reducer (turned backwards) --&gt; 3" flexpipe
Modified by pbsracerx at 9:34 AM 10/26/2004
Old Oct 26, 2004 | 02:24 PM
RNPoo7's Avatar
Default Re: (pbsracerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbsracerx &raquo;</TD></TR><TR><TD CLASS="quote">Here is what my builder did to fix the 2.5" to 3" exhaust conversion.
I might have to do. However, I dont' know if the muffler shops around me can be able to do that or not. I kinda live in the middle of no where. So if they can't, any idea where to get a flex pipe that has 2 differnet sizes on each side?
Old Mar 12, 2005 | 07:15 PM
thrty8street's Avatar
hwy where can i buy this 2.5 flexpipe?
Old Mar 12, 2005 | 07:21 PM
eg crunkmonster's Avatar
Default Re: (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">hwy where can i buy this 2.5 flexpipe?</TD></TR></TABLE>
ebay has them for cheappppp.
Old Mar 13, 2005 | 05:13 PM
Default Re: (eg cookiemonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster &raquo;</TD></TR><TR><TD CLASS="quote">
ebay has them for cheappppp. </TD></TR></TABLE>
anywhere else?
Old Mar 14, 2005 | 02:34 PM
94exguy's Avatar
Kteller.com sells them
http://www.kteller.com/store/p...d/210
matt
r0yal
Welding / Fabrication
Apr 19, 2006 07:03 PM
Del Slow
Apr 18, 2005 01:51 AM
tonezilla
Feb 15, 2005 07:17 AM
Sport_Injected
Oct 30, 2004 04:34 AM
