How much boost ??
Old Oct 28, 2004 | 05:57 AM
CrazyHB's Avatar
Default How much boost ??
stcok gsr head, built bottom end , sleeved , 84mm 9.5-9.8 comp. sc61 turbo...... how many pounds would be safe on a stock gsr head? (dont want to spend the money right now to get valves springs retainers).
also , either will be running hondata or aem ems.
also would 91 octane work or too mcuh problems?
i can get 93 if i have to..... only couple places have it.
let me know your inputs.
Thanks.
Old Oct 28, 2004 | 07:25 AM
CrazyHB's Avatar
Default Re: How much boost ?? (CrazyHB)
Old Oct 28, 2004 | 07:26 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyHB &raquo;</TD></TR><TR><TD CLASS="quote">stcok gsr head, built bottom end , sleeved , 84mm 9.5-9.8 comp. sc61 turbo...... how many pounds would be safe on a stock gsr head? (dont want to spend the money right now to get valves springs retainers).
Thanks.</TD></TR></TABLE>
w/ that kind of compression, Boost pressure will only truely be realized on the dyno. If your tuner is competent, then they will keep an eye on Air/fuel ratios, compression, and other attributes and you'll learn how far you can go from there. Especially w/ AEM or Hondata..
There's no true prediction. Go find out and see, honestly.
WalkerGSR1
Oct 25, 2006 04:12 PM
4CDFED
Jul 7, 2006 08:02 PM
Trak_Day
Dec 29, 2003 10:49 PM
Ryan C
Jul 7, 2003 08:19 PM
Blown90hatcH
Jul 30, 2001 04:54 PM
