Why do this BOV come with washer?
Old Oct 24, 2004 | 05:45 PM
StolenTeg's Avatar
Default Why do this BOV come with washer?
I was surfing through ebay and i come upon this BOV http://cgi.ebay.com/ebaymotors...33742. Im wondering why do the BOV come with the washers, what does those washer do or function as?
Old Oct 24, 2004 | 05:52 PM
project dc2's Avatar
Default Re: Why do this BOV come with washer? (StolenTeg)
functions as. tightenin the spring on a regular bov via the adjustable nut on top.
that bov doesnt have an adjustable nut. to the washers are used to pretension the spring so it doesnt open as soon. or so itll keep closed so boost wont leak.
Old Oct 24, 2004 | 05:57 PM
toolowsol's Avatar
Default Re: Why do this BOV come with washer? (project dc2)
Me fail engrish, thats unpossable.
honda13typer's Avatar
sounds like a ghetto way of doing but as long as it works i guess..
Old Oct 24, 2004 | 06:12 PM
StolenTeg's Avatar
Default Re: Why do this BOV come with washer? (honda13typer)
Hmm i dont really understand, So all those washers is suppose to go into the BOV? I assume that you can take the top off and put them in? what if there is no washer in there, then it will just leak off all boost?
Old Oct 24, 2004 | 06:24 PM
turbopimp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">Hmm i dont really understand, So all those washers is suppose to go into the BOV? I assume that you can take the top off and put them in? what if there is no washer in there, then it will just leak off all boost?</TD></TR></TABLE>
It depends on the spring tension. Adding more washers = shorter spring = more spring tension. Then you can run a higher boost pressure without worrying about leakage.
B18C1CYA's Avatar
just so you know that is not a real turboxs bov, but on the turboxs one the top unscrews so you can put the washers in to make the spring stiffer.
boostedSI90hatch
19
May 3, 2007 09:20 AM
bboysake
Aug 3, 2006 02:41 PM
whteteg8901
Feb 10, 2006 09:50 AM
civicshowracing65
Jan 8, 2004 08:19 PM
Jkan2001
Oct 2, 2002 04:39 PM
