Turbo rebuild
Old Oct 25, 2004 | 03:41 PM
sleepin91teg's Avatar
Default Turbo rebuild
Where do you guys get your turbo's rebuilt, if you buy a used one, and want it cleaned, and new seals and such? this is a garrett turbo...and i called garrett directly and they dont rebuild...
Old Oct 25, 2004 | 05:20 PM
TwoPointZero's Avatar
Banned
Default Re: Turbo rebuild (sleepin91teg)
When i bought my Garret T3/T04B turbo i purchased a rebuilt kit off of ebay. $65
Old Oct 27, 2004 | 07:39 PM
antiJDM's Avatar
Default Re: Turbo rebuild (TwoPointZero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoPointZero &raquo;</TD></TR><TR><TD CLASS="quote">When i bought my Garret T3/T04B turbo i purchased a rebuilt kit off of ebay. $65</TD></TR></TABLE>
did you do your own rebuild though?? or did you pay to have it done
Old Oct 27, 2004 | 07:41 PM
Banned
Default Re: Turbo rebuild (2thousandcivic)
i read up on it. made sure shaft wasn't bent and everything else was in reusable condition and i just did the rebuilding myself.
Old Oct 27, 2004 | 09:16 PM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoPointZero &raquo;</TD></TR><TR><TD CLASS="quote">i read up on it. made sure shaft wasn't bent and everything else was in reusable condition and i just did the rebuilding myself.</TD></TR></TABLE>
Cakelike, wasn't it? The only PITA is finding snap ring pliers small enough... or in the case of the last Holset I built, BIG enough.
Old Oct 28, 2004 | 06:47 AM
93turbo16's Avatar
Default Re: Turbo rebuild (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
The only PITA is finding snap ring pliers small enough... or in the case of the last Holset I built, BIG enough. </TD></TR></TABLE>
haha, good stuff. I am having that problem right now, rebuilding a straight T04B or something to that affect, haven't really figured out exactly what it is. But it is a beast.
Old Oct 28, 2004 | 07:48 AM
Default Re: Turbo rebuild (93turbo16)
I ground the tips of a set of needle nose pliers for the Holset's circlip that retains the thrust washer. Still required a LOT of weight to keep the pliers from slipping out of the holes, had to lean on it with my full 140lbs of awkward fury. The circlips that retain the bearings, however, are pleasantly bigger than T3 or the ****-in-the-***-miniature endless succession of IHI RHB5's people bring me. Those are quite simple to get out.
Old Oct 28, 2004 | 09:33 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">I ground the tips of a set of needle nose pliers for the Holset's circlip that retains the thrust washer. Still required a LOT of weight to keep the pliers from slipping out of the holes, had to lean on it with my full 140lbs of awkward fury. The circlips that retain the bearings, however, are pleasantly bigger than T3 or the ****-in-the-***-miniature endless succession of IHI RHB5's people bring me. Those are quite simple to get out.</TD></TR></TABLE>
LOL... I used tiny screw drivers grinded the tip to make it fit.. was kinda hard but kinda got the hang of it.
Old Oct 28, 2004 | 02:03 PM
Oh, yeah, completely forgot - I get most all my rebuild kits from TEC in Golden, CO, (800) 950-TURBO (yes, I realize the O doesn't do anything, but if I told you 950-TURB you might think I said TURD, you turds).
I've got a few Holset kits elsewhere, not entirely sure I'm happy with the service at this moment... there's some confusion, which could very possibly be on my end, so I'll withhold their identity until it gets sorted out.
Old Oct 28, 2004 | 02:12 PM
omahaturbocivic's Avatar
So what do all you guys do about balancing? Just mark the wheel shaft and nut before taking it off? I rebuilt the t3 turbo on my daily driver civic coupe 2 years ago with a kit from turbo city and it was not too bad. I did not know anything about balancing back then since their kit advertised "with basic hand tools". The turbo leaks a little oil when the car sits a while but does not smoke and otherwise has been going strong 2 years with no problems completely unbalanced .
EKlscoupe_98
Northeast (Sales)
Oct 7, 2008 07:10 PM
97preludeh22a4
Oct 25, 2006 05:20 PM
Tippyman
May 12, 2006 08:08 PM
acuracy r
Feb 20, 2005 08:49 AM
ityab0y
Feb 9, 2005 08:21 PM
