Sleeved block o ring replacement?
Old Oct 26, 2004 | 06:13 PM
Integralove00's Avatar
Default Sleeved block o ring replacement?
I want to see if anyone has run into the problem I am dealing with. I replaced my o rings on my sleeved block using 18 gauge "soft" copper wire as Golden Eagle suggested. They said I should be able to get the wire from any hardware store. The issue is how tall should the o rings be to provide propper seal with out preventing the headgasket to seat properly? Golden Eagle was unable to tell me. I am about to just buy their copper wire and redo it but at this point it is a matter of time and I really don't want to get their wire re o ring the block and find out the gasket still isn't seating. I know it is a long shot that anyone would know but if you do let me know.
Old Oct 26, 2004 | 08:46 PM
earl's Avatar
Default Re: Sleeved block o ring replacement? (Inte9ralove00)
tap the wire in the groove until it is sticking out about .010" and then hand stone it flat to about .005"-.007"
Old Oct 26, 2004 | 09:40 PM
Default Re: Sleeved block o ring replacement? (earl)
Thanks Earl.. once again you are the man.
Fatboii79
Jun 19, 2011 09:46 AM
glosssilver
Oct 18, 2005 10:22 PM
spooledex
Feb 17, 2004 09:44 AM
gritsak
Aug 19, 2003 12:00 AM
non-VTEC
Mar 3, 2002 08:54 AM
