ACCIDENTLY OVERTORQUED HSTUDS
Old Oct 23, 2004 | 07:19 PM
tiggyteg's Avatar
Default ACCIDENTLY OVERTORQUED HSTUDS
what could possibly happen if i over torqued the headstuds
btw: it was only for about an hour that they were over torqued. engine was never turned on. realized then loosened them
Modified by tiggyteg at 8:42 PM 10/23/2004
Old Oct 23, 2004 | 07:35 PM
tiggyteg's Avatar
Default Re: ACCIDENTLY OVERTORQUED HSTUDS (tiggyteg)
simple question... simple answer?
Old Oct 23, 2004 | 07:36 PM
norcalcrx's Avatar
They strip out? How much did you overtorque the?
Old Oct 23, 2004 | 07:37 PM
tiggyteg's Avatar
Default Re: ACCIDENTLY OVERTORQUED HSTUDS (norcalcrx)
70lbs...they still go in and out smoothly tho
Old Oct 23, 2004 | 08:09 PM
Boostfed's Avatar
New User
Perfectly fine!!! I torque mine to 81 ft-lbs with moly lube more than specs. I learned this from Golden Eagle and found out most of the big horsepower guys also torque them down this much. You will be fine. My motor has been torqued to 81 ft-lbs for a year or more now!
Old Oct 23, 2004 | 08:14 PM
cua0's Avatar
if you really overtorque them the threads will stretch beyond their elastic limit and cease to provide you with the 'holding power'..
Old Oct 23, 2004 | 08:53 PM
tiggyteg's Avatar
Default Re: ACCIDENTLY OVERTORQUED HSTUDS (cua0)
i meant 70lbs over meaning 140lbs
Old Oct 23, 2004 | 09:02 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tiggyteg &raquo;</TD></TR><TR><TD CLASS="quote">i meant 70lbs over meaning 140lbs</TD></TR></TABLE>
DOH!!!!!!!!!!!!
Old Oct 23, 2004 | 10:06 PM
PureTeg420's Avatar
Damn, well kiss those headstuds goodbye
Old Oct 23, 2004 | 10:11 PM
m R g S r's Avatar
Default Re: ACCIDENTLY OVERTORQUED HSTUDS (Boostfed)
Hmm, probally stretched out the studs, I don't even think it's worth the risk of re-using them, you might as well just shell out the extra $90.
Old Oct 23, 2004 | 10:15 PM
movedon's Avatar
not a big deal, car wasn't driven they still screw in and out fine, don't worry about it, but just don't do it again.
Old Oct 23, 2004 | 10:16 PM
movedon's Avatar
geez, I didn't read that one.
Old Oct 23, 2004 | 10:49 PM
SOHC_MShue's Avatar
good lord! It must have been hard getting them that tight.
Old Oct 23, 2004 | 11:03 PM
Hans Brix
Guest
Posts: n/a
Default Re: ACCIDENTLY OVERTORQUED HSTUDS (SOHC_MShue)
check the manufacturer of the bolt. They'll tell you what a safe tolerance for stretch would be. ARP being the stretch-***** they are - they say to toss em at anything over 0.1". But damn...140ft/lbs. Just out of curiosity - when you had to use an 11ft breakerbar to get them that tight and your head started to warp up like a pinched sandwitch - did it ever click that something was wrong?
Old Oct 23, 2004 | 11:23 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Congrats, you just made a $90 mistake.
Old Oct 23, 2004 | 11:25 PM
Sonny's Avatar
Damn. I'm surprised the studs didn't pull right out the block.
sonny
Old Oct 23, 2004 | 11:27 PM
Nikoli's Avatar
Default Re: ACCIDENTLY OVERTORQUED HSTUDS (boostincoupe)
i thought arp's were good for like 190,000psi tensile strength or sumn like that?
you would think the block or the head would've been affected first huh?
aluminum vs. steel
Old Oct 24, 2004 | 12:11 AM
Hans Brix
Guest
Posts: n/a
Default Re: ACCIDENTLY OVERTORQUED HSTUDS (Deckedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">i thought arp's were good for like 190,000psi tensile strength or sumn like that?
aluminum vs. steel </TD></TR></TABLE>
I don't know what ARP states their tensile strength is - but I've yet to see any bolt survive severe overtorquing. Especially DOUBLE what they're suggested at. $90 studs would be amazing if that's all that's damaged. I'll place a wager on the head also, at the very least. Just waiting to see the post creator come back and say "hey guys - all the bolts feel really loose when I started loosening them. I'm gonna take em all out, then let you know how it went." Then come back and post a pic with a handfull of bolt heads. Fun times. Live and learn.
Old Oct 24, 2004 | 07:02 AM
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
good lord! It must have been hard getting them that tight.</TD></TR></TABLE>
same thing I was thinking
Old Oct 24, 2004 | 08:20 AM
nos51's Avatar
steroids!!!!!!!
Old Oct 24, 2004 | 10:10 AM
menkio's Avatar
Default Re: (nos51)
wtf.. how do you **** up 70lbs..
lol.. yea you need new headstuds. Also, goto a machine shop, have them finish this assembly for you. I would have you install a wiper blade on my car.
Old Oct 24, 2004 | 11:56 AM
AMS MIKE's Avatar
wow.
Time to buy a Helm's Manual. It's ONE of the tools you need when working on an engine! That way you will hopefully not make a costly mistake like you have already done.
http://www.helminc.com
Old Oct 24, 2004 | 12:47 PM
Boostfed's Avatar
New User
Damn guys! Leave the guy alone! He came on here for help!!! I dunno how he overtorqued it by that much BUT it happen, now I am sure he feels really bad and thinking he may have screwed something up! And he came on here for advice. Don't slam him further! ****! Good luck man, I think the head studs are done with that much overtorque on them. Make sure when you pull them out that the thread holes are clean, take some compressed air and clean it out good, make sure you don't have you rthreads all jacked up too. Maybe have a machine shop look at it for you. Good luck bro!
Old Oct 25, 2004 | 06:53 AM
tiggyteg's Avatar
Default Re: (Boostfed)
so yall thinkm y block is ok and i should just get new studs?
Old Oct 25, 2004 | 07:13 AM
Rod.'s Avatar
Default Re: (tiggyteg)
I think your block should be ok. Like boostfed said, let a machine shop look at it
Modified by redturbocivic at 8:27 AM 10/25/2004
