Whats the highest boost you can get from a 60-1 turbo?
I am at 27 psi and just curious if anyone has actually run higher than that. Yes, I have looked at the compressor map and it looks about done at that boost level, but I am curious if anyone that is actually using a 60-1 compressor on their engine has run higher.
Thanks,
ZEX Man
Thanks,
ZEX Man
Re: Whats the highest boost you can get from a 60-1 turbo? (ZEX Man)
thats about all i could get out of mine as well even with the 62-1 wheel upgrade it still would only push about 30 max
I did 25psi out of mione, I think it only has 27-28psi max out of it! Key word from me was "THINK"! Good luck!!! Put a bigger turbo on there Matt and run some 9's!!!!!!!!!
Edit:What turbine? T3 or T4? You could always step up on the turbine housing A/R. So if you have a .68 A/R bring it up to an .81 A/R , you git NAAAAWSSS so it shouldn't be too much of a problem with spool! Now run 9's SOHC style!
