3 Bar Map sensor problems *D-Series/Uberdata*
Old Oct 25, 2004 | 12:59 PM
MiKeAhOwSkI's Avatar
Default 3 Bar Map sensor problems *D-Series/Uberdata*
Hey guys, I'm trying to get my 3bar to start up with Uberdata. I'm wondering if there's any options in Uberdata I have to check for the 3 bar besides actually choosing the 3 bar map sensor under the boost tab?
When I turn the key the fuel pump doesn't prime and the CEL goes off like normal and comes right back on after a few seconds. throws code 0 ; ECU failure I think.
Anyways, I used Hondatas instructions to splice it in. Today I noticed on the Hondata site it says B-series... Anyone know what wires to splice on a d16z6 for the 3 bar? The colors are the same so I don't Know...
When I re-burn my old chip with the stock sensor it starts like normal.
Any Help is appreciated cause I need more Booooost !
Old Oct 25, 2004 | 03:34 PM
platinum00's Avatar
Default Re: 3 Bar Map sensor problems *D-Series/Uberdata* (MiKeAhOwSkI)
did use this doc.
http://www.hondata.com/3barinstall.html
also did you check the voltage's as stated in the install.
what ecu are you running.
i wired it like above and im running a p28..
i got a feeling its your software , not the wiring.
platinum.
Old Oct 25, 2004 | 06:00 PM
psileepR's Avatar
New User
Default Re: 3 Bar Map sensor problems *D-Series/Uberdata* (platinum00)
Bump for Mike.
Help this good guy out
Old Oct 25, 2004 | 06:03 PM
tubegown's Avatar
Im bored, PM me your AIM address and Ill take care of the problem with you on there.
ej1252
Nov 3, 2007 07:40 PM
h22sedan
Dec 3, 2006 07:46 PM
NA JDM GSR
Oct 29, 2006 08:38 AM
EX-T
May 26, 2006 05:06 AM
jsimon9633
May 27, 2005 07:43 PM
