yet another tranny problem..
Old Oct 25, 2004 | 01:09 PM
turbod16y7vtec's Avatar
Default yet another tranny problem..
so i bought my tranny through a great seller honest and all that crap.. well its suppost to be in perfect condition and my problem is that when i am driving normal 2nd. gear seems to be a bitch and not want to grab..only sometimes though.. not on hard shifting or anything like.. just normal or on turns it will pop out of gear.. i am running synchro mesh (however you spell it) i checked the tranny and it is full, i have checked the shiftlinkage and everything is grand.. so what would it be? is 2nd gear going bad?
thanks in advance
Old Oct 25, 2004 | 01:17 PM
underpressure02's Avatar
Default Re: yet another tranny problem.. (turbod16y7vtec)
The only time my tranny would pop out of gear is when the fluid was low. Are you sure it is full?
Old Oct 25, 2004 | 01:32 PM
Default Re: yet another tranny problem.. (underpressure02)
i will double check my self thanks
Old Oct 25, 2004 | 01:37 PM
if your car is lowered try and make sure it is level. I know when I had my car raked front end lower then the back the oil would come out of the hole like it was full but when you jacked the car up to make it level it still needed some more fluid.
Old Oct 25, 2004 | 05:28 PM
well again its full..anything else? is there some kind of spring.. i heard something about a ball and spring holds it in gear? am i just full of bs or could it be that?
Old Oct 29, 2004 | 08:58 PM
M.A.R.C.'s Avatar
bump for Brett
Old Oct 29, 2004 | 09:03 PM
Blown90hatcH's Avatar
Default Re: yet another tranny problem.. (M.A.R.C.)
Bearing on the end of the mainshaft is probably going bad. Does it whine?
jimboek
17
Apr 26, 2007 03:48 PM
B16Jacques
Sep 17, 2006 09:26 PM
JDM-EJ698
Sep 1, 2006 03:26 PM
IEATLINT
Sep 10, 2004 12:53 PM
PrecisionH23a
Jun 16, 2003 07:29 AM
