D17a Fuel Management
Old Nov 22, 2004 | 12:16 PM
MooreBoost's Avatar
Default D17a Fuel Management
A local guy wants to purchase a turbo kit from me but he runs a D17a and is stumped as far as fuel management. It's a returnless system and the only larger injectors he knows of are RSX, which are only like 310cc I think. What do you D17a guys do for fuel?
Old Nov 22, 2004 | 12:34 PM
SOHC_MShue's Avatar
Default Re: D17a Fuel Management (tegunderpressure)
well he could run an fmu
Old Nov 22, 2004 | 12:37 PM
beepy's Avatar
Options:
1) Kenne Bell Boost-a-Pump (Basically the same as a FMU, but works for pulse-modulated, returnless fuel systems)
2) The hizack (but you said you cannot find injectors?)
3) Supplementary fuel system (EIC, tap fuel lines)
I would say the best thing to do would be to run an EIC. But I have a similar configuration and run a modified SAFC.
Old Nov 22, 2004 | 12:47 PM
ComputerJLT's Avatar
convert to a return style setup and convert to obd1 electronics and run uberdata
Old Nov 22, 2004 | 12:52 PM
MooreBoost's Avatar
Default Re: D17a Fuel Management (ComputerJLT)
E-manage sounds like the only way after the research Ive done.
Old Nov 22, 2004 | 05:11 PM
opto_isolator's Avatar
http://www.7thgencivic.com/for...+fuel
http://www.7thgencivic.com/for...40975
boostfed-wwjd
Apr 23, 2007 06:36 AM
big juan
Oct 29, 2005 06:59 AM
projectxspeed
Apr 15, 2005 08:19 AM
