turbo carb engine
Old Nov 21, 2004 | 05:21 PM
civictildeath's Avatar
Default turbo carb engine
if i put a 1987 d15a2 carbureted crx engine in a 97 civic what would need changed out as far as fuel pump, ecu (if one) fuel lines, and other things i may need to change??
Old Nov 21, 2004 | 06:47 PM
poop II's Avatar
Default Re: turbo carb engine (civictildeath)
Wow, that would be different. The carb will more than likely leak, so I guess you'll have to get special seals and the carb body machined to accept them. I know little about honda's so im not going to lend advice on the rest. If you want to be that radical, how bout a draw through setup with say, a 40dcoe? Expect more people to tell you to not bother than give advice.
Old Nov 21, 2004 | 07:02 PM
Default Re: turbo carb engine (poop II)
thanks i just figured it would be cheaper to turbo and build since it needs no ecu upgrades
Old Nov 21, 2004 | 07:05 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">thanks i just figured it would be cheaper to turbo and build since it needs no ecu upgrades</TD></TR></TABLE>
Chipping an ECU costs 50 bucks. Dont let that discourage you. Getting a carbeurated turbo car to run well will be a hell of alot harder than chipping an ECU.
Old Nov 21, 2004 | 09:58 PM
Default Re: turbo carb engine (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Chipping an ECU costs 50 bucks. Dont let that discourage you.</TD></TR></TABLE>
damn i thought it was way more than that. think il jst turbo my engine in there now. thanks a lot
Old Nov 21, 2004 | 10:03 PM
SOHC_MShue's Avatar
yea that would be a big project...just turbo the engine you got now.
josh fischer
May 14, 2019 12:23 AM
jdmjin
May 15, 2008 11:20 AM
st81
Aug 24, 2006 10:43 AM
slipstream2005
Mar 7, 2005 11:49 AM
j_kevin_ca
Nov 4, 2004 10:00 AM
