TURBO!!!
Old Nov 18, 2004 | 06:56 PM
aznsins88's Avatar
Default TURBO!!!
Hey guys, I might be getting a turbo for my car soon so I was wondering if these parts are any good? BTW I have a 1994 Integra GSR.
Drag High flow 4 into 1 cast iron turbo exhaust manifod
Turbonetics T04 / T3 turbocharger
Tial Wastegate
Spearco front mount intercooler w/ polished tanks
BLITZ dual drive Blow Off Valve
Drag mandrel bent high flow chrome plated intercooler pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegaste dump tube
Heavy Duty silicone hose and hose clamps
Walbro 255 Fuel Pump
Vortech 12:1 Boost dependent FMU fuel regulator
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Any opinions would be great...thanks!
Old Nov 18, 2004 | 07:04 PM
dunkd's Avatar
everything sounds good... ditch the FMU and bypass valves...
read up on fuel management like injectors and something to control them with (uberdata, hondata, aem ems)
Old Nov 18, 2004 | 07:09 PM
aznsins88's Avatar
Default Re: (dunkd)
why should i ditch those? are they not useful or just bad?
Old Nov 18, 2004 | 07:13 PM
PrettyLude's Avatar
its just a starter kit, and to maximize power you have to go with real fuel management
Old Nov 18, 2004 | 07:19 PM
aznsins88's Avatar
Default Re: (PrettyLude)
o ite. wat are some good real fuel management?
Old Nov 18, 2004 | 07:21 PM
adictionbass's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">everything sounds good... ditch the FMU and bypass valves...
read up on fuel management like injectors and something to control them with (uberdata, hondata, aem ems)</TD></TR></TABLE>
Old Nov 18, 2004 | 07:30 PM
adseguy's Avatar
Default Re: (aznsins88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznsins88 &raquo;</TD></TR><TR><TD CLASS="quote">o ite. wat are some good real fuel management?</TD></TR></TABLE>
Use keywords: AFC, Hack, Uberdata, Hondata, AEM EMS
These searches should give you tons of information on different fuel managements. READ UP
Old Nov 18, 2004 | 09:02 PM
PureTeg420's Avatar
Default Re: (adseguy)
no reason to include AFC and hack in your search, I'm sure he doesn't want poor man's attempt at a tuning solution.
Old Nov 18, 2004 | 09:10 PM
aznsins88's Avatar
Default Re: (PureTeg420)
ahahhaha nice wat to put it!
Old Nov 19, 2004 | 05:47 AM
adseguy's Avatar
V-AFC and S-AFC arn't bad at all. I mean even hondata sucks compared to it's true standalone counterpart AEM EMS. FMU's suck because it really forces fuel instead of dealing it out correctly . What is the reason you don't like AFC's?
Old Nov 19, 2004 | 07:02 AM
dunkd's Avatar
aem ems &gt; hondata &gt; uberdata &gt; afc hack &gt; FMU
thats basically how it goes.
Old Nov 19, 2004 | 08:31 PM
aznsins88's Avatar
Default Re: (dunkd)
oOo ok.
Old Nov 19, 2004 | 08:51 PM
jpenman50's Avatar
For a basic bolt on turbo kit (Stock bottom end) tuning is going to be key for max power and engine reliability. For good tuning turn to a hondata with 550 cc injectors so you can tune for more with plenty of fuel. With fine tuning on a hondata you can easily make 300 hp on pump 91 (low boost 7-9 psi). The nice thing about Hondata is it retains the factory ecu, (Chrome, Uberdata, and neptune do also) for streetability. Let me know if I can help you with a hondata and base chip.
Jasen PMS
7mile
Dec 25, 2005 09:41 AM
7mile
Nov 25, 2005 01:29 PM
milton
Oct 19, 2005 10:07 AM
Retired
Oct 5, 2005 06:45 PM
Carlito Brigante
Aug 3, 2004 10:16 AM
