are these injector clips broken?
Old Nov 18, 2004 | 02:20 PM
DFW's Avatar
DFW
Default are these injector clips broken?
I was wondering if thses are borken or messed up. are these long enough for it to work? or does it look like i have to add wires to it
in the first pic it shows a clip with a metal paper clip thing around it but it doesnt even line up right,what are the purpose of the paper clip things?
in the second pic, it doesnt even have it at all
Old Nov 18, 2004 | 02:27 PM
msmotorsports's Avatar
Default Re: are these injector clips broken? (DFW)
You will need to add wire because it was cut off of another car. The "paper Clips" hold the connectors onto the injector. You will need to have all of these clips for safety reasons. Just imagine making a pass in 3rd gear and have one of the clips fall off at 7000RPM.
Old Nov 18, 2004 | 02:59 PM
onePOINTsix's Avatar
Default Re: are these injector clips broken? (msmotorsports)
that really wouldnt do anything, just make it run on 3 cyls. And before you say it will make it run lean, it cant run lean on that cyl, theres no fuel but anyway you do need to get another one of those little metal clips
Old Nov 18, 2004 | 05:05 PM
DFW's Avatar
DFW
Default Re: are these injector clips broken? (onePOINTsix)
Thanks for the responses
Old Nov 18, 2004 | 10:29 PM
SOHC_MShue's Avatar
i have a similar question...i have been getting weird detonation problems ever since it got cold outside. My car runs smooth and my afr's are in the high 11's to high 10's and i'm still detonating. This is also with fairly conservative timing maps. I've asked a lot of people and nobody can tell me what is wrong. One of my injector clips has a part of the plastic piece broken off and no paper clip thing. I just have it held on with a ziptie. Is it possible that it could be making a connection, but not well enough for the injector to work properly? Could I be leaning out on just that one cylinder and still getting rich overall afr's?? I got a new clip i'm gonna solder on when i get the chance so hopefully that was my problem. I can't really test it out right now though because i just blew my hg.
Old Nov 19, 2004 | 05:34 AM
SOHC_MShue's Avatar
Default Re: are these injector clips broken? (SOHC_MShue)
bump
Old Nov 19, 2004 | 08:13 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">i have a similar question...i have been getting weird detonation problems ever since it got cold outside. My car runs smooth and my afr's are in the high 11's to high 10's and i'm still detonating. This is also with fairly conservative timing maps. I've asked a lot of people and nobody can tell me what is wrong. One of my injector clips has a part of the plastic piece broken off and no paper clip thing. I just have it held on with a ziptie. Is it possible that it could be making a connection, but not well enough for the injector to work properly? Could I be leaning out on just that one cylinder and still getting rich overall afr's?? I got a new clip i'm gonna solder on when i get the chance so hopefully that was my problem. I can't really test it out right now though because i just blew my hg.</TD></TR></TABLE>
sure you are detonating and not misfiring?
check your plugs with a magnifying glass...
Old Nov 22, 2004 | 06:58 AM
Issabsb30's Avatar
zip ties work fine if used properly.
BigMoneyP
Feb 12, 2006 05:04 PM
RACEPAK
Aug 15, 2005 01:27 AM
BLACKLUDE97
Dec 24, 2003 04:25 AM
