dyno results
Old Nov 21, 2004 | 07:57 AM
seen4ever's Avatar
Default dyno results
We had a big dyno meet on saturday at automotion, pretty much most of the big power guys from around town showed up, so i went ahead and threw my hatch on the rollers.
video - dyno pull
http://clubvwoflouisville.com/...7.mpg
video - 1/4mile simulation (see no traction)
http://clubvwoflouisville.com/...8.mpg
results:
specs:
b18c1
Endyn rollerwave pistons (20 over)
Eagle rods
550cc injectors
stock head
Autolab Tubular manifold, 3in dp, dumptube
Forced Performance t3/t40e, 60trim, .63ar, stage 5
35mm Tial, blitz bov
3in Thermal
hondata s200 (tuned by myself via street)
PLX m300 was the wideband i used
14psi, pump gas
I'll post up a datalog from the hondata later, but A/F stayed between 12.1 - 11.4.
i just wish i had an upgraded valvetrain, my hp curve never stops rising, but the stock springs keeps be shifting at 8100.
Old Nov 21, 2004 | 08:02 AM
hondaguyef's Avatar
Default Re: dyno results (seen4ever)
Excellent
Phil
Old Nov 21, 2004 | 08:22 AM
Civic_95_Si's Avatar
I'd pull so hard.
Old Nov 21, 2004 | 08:37 AM
Boosted Chemist's Avatar
Default Re: dyno results (Civic_95_Si)
nice clean curve
Old Nov 21, 2004 | 08:40 AM
seen4ever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_95_Si &raquo;</TD></TR><TR><TD CLASS="quote">I'd pull so hard. </TD></TR></TABLE>
i fear the SOHC par
Old Nov 21, 2004 | 09:24 AM
SkRiBLaH's Avatar
how the hell can it be zero hp untill 4400?? that confuses me.
Old Nov 21, 2004 | 09:30 AM
FOrSfEd's Avatar
Default Re: dyno results (SkRiBLaH)
Nice numbers
Old Nov 21, 2004 | 09:57 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">how the hell can it be zero hp untill 4400?? that confuses me.</TD></TR></TABLE>
That's where they hit "REC"
Phil
Old Nov 21, 2004 | 10:08 AM
turboEGhatch's Avatar
Did it go a simulated 11.75@116 on the dyno, or was that at the strip? That sounds kinda low for 350 WHP......
Old Nov 21, 2004 | 10:09 AM
JDMs1eeper's Avatar
Nice Numbers
Old Nov 21, 2004 | 04:58 PM
seen4ever's Avatar
Default Re: dyno results (turboEGsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGsedan &raquo;</TD></TR><TR><TD CLASS="quote">Did it go a simulated 11.75@116 on the dyno, or was that at the strip? That sounds kinda low for 350 WHP......</TD></TR></TABLE>
that's at the strip. I've since tuned the top end better, i was sinking into low 11:1, 10:1 a/f ratios during the pass, so once i got into 4th, it really just died on its face at the top of the strip. Like someone said, they didn't even start recording til around 4400rpms. I was happy with the power and I'm sure i could get to mid 11s if i kept this setup. I have plans over the winter to change a few things, which should hopefully get more power, plus i plan to start tuning for race gas as well.
Old Nov 21, 2004 | 05:19 PM
elitesi8's Avatar
Where in Louisville are you from, I just came back off leave from there, over off of Preston HWY.
Old Nov 21, 2004 | 05:22 PM
nsxmatt's Avatar
Default Re: dyno results (elitesi8)
Nice numbers
Wish I had 100 more whp & tq
Old Nov 21, 2004 | 08:18 PM
seen4ever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elitesi8 &raquo;</TD></TR><TR><TD CLASS="quote">Where in Louisville are you from, I just came back off leave from there, over off of Preston HWY. </TD></TR></TABLE>
i live off preston as well, get on 502streetscene.net for more local people.
matt, if you had 100more hp & torque, you would really kill me on at the street. you run faster than i do with 100whp less
Old Nov 21, 2004 | 09:05 PM
SLVRSTN_DC4's Avatar
very impressive
Old Nov 21, 2004 | 09:57 PM
XxRoCkMaNxNEOxX's Avatar
Default Re: dyno results (HyptCvc_)
does the mustang dyno produce higher numbers than the dynojet?
Old Nov 22, 2004 | 04:33 AM
seen4ever's Avatar
Default Re: dyno results (XxRoCkMaNxNEOxX)
normally mustang dynos read a little lower than dynojets. I plan to throw it on a dynojet before i put on the new turbo.
Old Nov 22, 2004 | 09:04 AM
seen4ever's Avatar
datalog of my last dyno run.
MILANO_RED_CL9
Acura TSX
18
Feb 9, 2011 02:21 PM
blueintegra
Jun 28, 2007 12:44 AM
D@nnY
Mar 30, 2004 01:00 PM
TurboDelSol
Mar 13, 2003 08:09 AM
MotorMatrix.com
Jan 13, 2003 07:11 AM
