anyone using Defi Link Display ???
Old Nov 21, 2004 | 06:24 AM
Squirtin EGsr
Guest
Posts: n/a
Default anyone using Defi Link Display ???
what is needed for this to work ? i dont really under stand what its saying
Defi-Link Display is a multipurpose monitor which provides information on speed, oil temperature, water temperature, oil pressure, fuel pressure, and exhaust temperature by connecting to the Defi-Link Control Unit II or the Defi-Link Control Unit. Defi-Link Display can be connected to Defi-Link Meters and Defi-Link Meter BFs by using the DAISY CHAIN wiring system.
im thinking all i need is this....
Defi Link Display
Defi Control Unit
here is a pic of the control unit
what im not really under standing is how that unit can read oil pressure, fuel pressure, and exhaust temperature from stock sensors ? if it can then thats kinda a good deal for 400.00 you can read all that on one display!
can somone please help me ?
Old Nov 21, 2004 | 06:31 AM
B16A1-EF9's Avatar
No you need to the contoller then all the gauges that you want to run deom Defi also. You hook up the sensors that come with the gauges to the controller from the controller to the gauges. Thats what ties it all together. The display is optioanl I think.
There are many guys on here that have this setup, I'm sure they can give you a better idea of how it all works.
I believe "Tony the tiger" has this system in his Camry also.
Old Nov 21, 2004 | 06:52 AM
Squirtin EGsr
Guest
Posts: n/a
so the controle unit doesnt have come with the sensors ... so i have to buy all the gauges for the link display to work ?... then thats like 1500.00 in guages or somthing ... what would be the point in buying the link display if you have all the gauges ?
Old Nov 21, 2004 | 04:32 PM
Squirtin EGsr
Guest
Posts: n/a
anyone else have input on this >?
Old Nov 22, 2004 | 04:53 AM
pissedoffsol's Avatar
25 Year Member
Default Re: (RiceRocket12s)
you're corret- its liek 1500 bucks. the display unit is an add-on to put all the readings in one place. thats about it. you still need the gauges and sensors and link stuff for it to work
Old Nov 22, 2004 | 06:59 AM
4-banging's Avatar
Default Re: (slow poke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke &raquo;</TD></TR><TR><TD CLASS="quote">
That’s not needed You guys are misleading this guy!
You buy the link display, control unit, and INDIVUDAL SENSORS!
No need to buy the gauges, just the sensors
Do it! You will love it
http://www.defi-shop.com
correct. all you need is the controller unit and the necessary gauges. the gauges come with the wiring you need and other misc. items. the display is another "add-on" you can buy.
Old Nov 22, 2004 | 07:48 AM
Dee's Avatar
Dee
Default Re: (4-banging)
I have it! I only have the display on my dash for guages (boost, EGT, Fuel psi, oil psi, oil temp)!!
You buy the display, the controller and the sensors of your choice! The damn pressure sensors require a 1 kidney sacrifice before purchase. I actually already had the gauges so I bought the display and sold the gauges to friends who wanted to be cheap.
Old Nov 23, 2004 | 09:57 AM
Squirtin EGsr
Guest
Posts: n/a
how much did you guys spend on the unit , controller, and sensors ? .... NO GAUGES
Old Nov 23, 2004 | 10:11 AM
Squirtin EGsr
Guest
Posts: n/a
if i priced this up right its saying 1,000.00 for everything ... am i right ?
Defi Link Display 280.50
Defi Replacement / Repair Parts: Oil Press Sensor Set (1/8PT) 148.75
Defi Replacement / Repair Parts: Fuel Press Sensor Set (1/8PT) 148.75
Defi Replacement / Repair Parts: Exhaust Temp Sensor Set (1/8PT) 175.95
Defi Replacement / Repair Parts: Boost Sensor 142.80
Defi-Link Control Unit II 109.65
Total 1006.40
does that look right ?
Old Nov 23, 2004 | 01:53 PM
ITRTurbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceRocket12s &raquo;</TD></TR><TR><TD CLASS="quote">if i priced this up right its saying 1,000.00 for everything ... am i right ?
Total 1006.40
Don't you need wires also?
Old Nov 23, 2004 | 05:00 PM
Dee's Avatar
Dee
Default Re: (ITRTurbo)
It comes with the wires!
Old Nov 23, 2004 | 05:44 PM
Squirtin EGsr
Guest
Posts: n/a
cant just use any old wire ?
Old Nov 23, 2004 | 06:26 PM
V-SPEC 1's Avatar
no, you have to have the wires that come with them, it plugs into the displays.
Old Nov 24, 2004 | 07:47 AM
White Smoke's Avatar
i my honda
Global Mod
Exactly right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">It comes with the wires!</TD></TR></TABLE>
Old Nov 30, 2004 | 09:41 PM
endlesswinterco's Avatar
Default Re: (si2die4)
damn kyle, mr. uncle penny bags here. spending some cash
DC231 Sean
Mar 1, 2005 07:43 PM
