Arias Pistons
Old Nov 24, 2004 | 03:52 AM
H22aAccord's Avatar
Default Arias Pistons
Anyone have any experience with them, heard good or bad things about them?
I might get their 9.0:1 pistons for a awesome deal
Old Nov 24, 2004 | 04:35 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Arias Pistons (H22aAccord)
arias pistons are off the hook , if you can get an awsome deal on them , then do it.
Old Nov 24, 2004 | 06:59 AM
RA166E's Avatar
I'm running them and have had awsome results. I put these pistons through Hell.
Old Nov 24, 2004 | 07:03 AM
gitwidit's Avatar
Default Re: Arias Pistons (RA166E)
Good pistons, ran them on my first setup
Old Nov 24, 2004 | 07:12 AM
X-Mazda 3 Racer's Avatar
Default Re: Arias Pistons (GITWIDIT)
I use them on all of my race engines. Best pistons on the market IMO!!! Top quality, top tolerances, top performance. Once I put them in the Bergenholtz Mazda 6, 2 races later they went 7's! I cannot say enough about them!
http://www.AriasPistons.com
Beeri is the man behind the best pistons in the world.
Old Nov 24, 2004 | 08:51 AM
psileepR's Avatar
New User
Default Re: Arias Pistons (GoldenEagleMfg.com)
We run Arias pistons in all of our customers' cars that want to go all out power. Tolerances have always been very accurate. No problems at all with them.
Arias
Old Nov 24, 2004 | 10:20 AM
H22aAccord's Avatar
Default Re: Arias Pistons (psileepR)
thanks im getting them new for 300 with rings. ill grab them then, can i use the rings given from arias or is the oem ones better?
Old Nov 24, 2004 | 11:03 AM
Use the rings that Arias supplied. They are the best!
Old Nov 24, 2004 | 12:21 PM
ExospeedAMcrx's Avatar
I agree with GE here. We use Arias in all our engines as well. Arias pistons have been good to us and will always be using them.
Old Nov 24, 2004 | 01:40 PM
LSVtechnologytur...'s Avatar
Default Re: (exospeedAMcrx)
i love hearing stuff like this after ordering a combo set of arias off of exospeed
Old Nov 24, 2004 | 02:17 PM
mildly.interesting's Avatar
Arias 8:5.1 in my LS, but Total Seal rings...
Old Nov 24, 2004 | 04:47 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (mildly interesting)
how you like the total seal rings?
Old Nov 24, 2004 | 04:58 PM
PrettyLude's Avatar
i think its not worth the money
Old Nov 24, 2004 | 05:25 PM
Default Re: (Hella_JDM is back!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM is back! &raquo;</TD></TR><TR><TD CLASS="quote">how you like the total seal rings?</TD></TR></TABLE>
20 lbs on pump gas with no blow-by...
what's not to love?
Old Nov 24, 2004 | 06:25 PM
the piston rings that come with the ARIAS piston set is good enough. we use the complete ARIAS piston kit w/rings on all the engines we use. from 200hp all motor cars to 800hp turbo race cars.
Old Nov 24, 2004 | 06:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">the piston rings that come with the ARIAS piston set is good enough. we use the complete ARIAS piston kit w/rings on all the engines we use. from 200hp all motor cars to 800hp turbo race cars. </TD></TR></TABLE>
sorry man, that's not what I as looking for. I daily drive my car, get 38 mpg, and run a best of 12.2 @ 117...I'm not knocking the Arias rings, but they were not for me.
Old Nov 24, 2004 | 06:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mildly interesting &raquo;</TD></TR><TR><TD CLASS="quote">
sorry man, that's not what I as looking for. I daily drive my car, get 38 mpg, and run a best of 12.2 @ 117...I'm not knocking the Arias rings, but they were not for me.</TD></TR></TABLE>
oh im not saying Total Seal are not good rings.
I'm just saying that the Rings that come in the Arias kit work real well.
2 Hot Rod cars in the 9s and numerous 11 sec daily street cars that have come out of our shop have been successful in using the Arias rings.
Old Nov 24, 2004 | 07:25 PM
H22aAccord's Avatar
Thanks i just bought the arias pistons with crower rods for my h22
Old Nov 24, 2004 | 08:17 PM
2 Hot Rod cars in the 9s and numerous 11 sec daily street cars that have come out of our shop have been successful in using the Arias rings.</TD></TR></TABLE>
right on
Old Dec 1, 2004 | 08:23 PM
H22aAccord's Avatar
Is 8:1 compression on an 87.5 mm too low considering ill be boostin 20psi?
Old Dec 1, 2004 | 08:25 PM
PrettyLude's Avatar
why don't you try 9 to 1?
Old Dec 1, 2004 | 08:31 PM
Default Re: (H22aAccord)
Arias has a piston that is 9.2 that is 87.5 . That is perfect for high boost street or strip application.
It is Arias part # 3310600 That is what I would use!
Old Dec 3, 2004 | 06:41 PM
H22aAccord's Avatar
Default Re: (GoldenEagleMfg.com)
Well the ones i got were sutom made for an h23 for 8.5:1. But on an h22 it drops to lower to 8:1 and was wondering if those were to low considering i was going to get them hea coated and get the cometic shorter head gasket.
Also ccometic doesnt make an 87.5mm head gasket, so will the 87 be fine to use?
Old Dec 5, 2004 | 08:04 PM
I'd suggest selling the pistons you have and getting the ones you need. We can help you out. Hit me up and I can try to get rid of those pistons for you and you can use that $ toward a set of new Arias that are exactly what you need.
Also, the stock gasket CAN accomodate an 87.5 mm piston. It was made to be able to got 1/2 mm oversized, so your golden!
kennie555
Feb 21, 2013 04:32 PM
tony n.
Jul 19, 2006 04:58 PM
GDM Z28
Jul 28, 2004 02:06 PM
xxthabest1xx
Apr 30, 2003 08:30 PM
