Boosted JDM H22a blown head gasket?????
so, it's been really cold lately and i've been creeping into 11-12psi and after some serious beating on the car it now runs like ****. i have oil and smoke coming out of my valve cover breather, also i did a compression check and it looked like this:
100 - 150 - 40 - 190
when i did one a month ago it looked like this
190 - 182 - 182 - 190
i have no more than normal smoke out my exhaust, and my plugs are the most perfect shade of grey. but on the front of the block between the head and the block i have oil coming out of there. i'm not really burning too much oil, and i am burning no coolent what so ever. the car stays in perfect temp all the time.
anyone know what this would be??
thanks in advance
thanks in advance
Re: (PrettyLude)
if the ringlands are gone, wouldn't i be burning tons of oil??
cuz i blow absolutely no oil, and the level of the oil hasn't changed since this happened.
and if it's the ringlands, explain the oil leaking from between the head and the block?? lol
Re: Boosted JDM H22a blown head gasket????? (93BoostedAcclude)
if theres oil and smoke out of the breather i would think its more than just a headgasket.
Re: Boosted JDM H22a blown head gasket????? (SOHC_MShue)
key thing is you said " i would think" so really you have absolutely no idea what you are talking about and just wasted a post in my thread.
anyone with some real knowledge have an idea??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93BoostedAcclude »</TD></TR><TR><TD CLASS="quote">key thing is you said " i would think" so really you have absolutely no idea what you are talking about and just wasted a post in my thread.
anyone with some real knowledge have an idea??</TD></TR></TABLE>
how about you go **** yourself. I was trying to help you, but all you could do was insult me. I have blown 3 headgaskets on my car and my valve cover breather never once blew out oil or smoke. Just think about it *******. You have shitty compression and are obviously getting blowby. Your piston rings are probably fucked.
Re: (PrettyLude)
then wouldn't i have oil coming out of my exhaust???
explain how blow by would cause smoke and oil out my valve cover breather?
and explain why oil is leaking from the head gasket?? but you say it's not the head gasket
you guys say this and say that but you haven't explained anything yet.
i thought honda-tech had knowledgable members who will give good discriptions about what they think is going on.... all i've seen so far is what someone thinks, but they have no way to explain why they think that. i've come to realize that asking people who you think know their ****, usually are wrong.
but, if it is my ringlands, then i will personally come to each of your homes and give you all blow jobs
Re: (Alstare)
haha, i wouldn;t have went as far as ******** . the reason why we are saying ringlands is because its the weakest part on the hseries motor, and if you search the archives you'll see about 15 stories that sound like yours where it ended up being the ringlands. It could be the headgasket, but i personally have never seen compression drop that bad because of a head gasket. try a leak down test and see what you get
Re: (b16hybridsol)
well if it makes any difference i haven't stopped driving it lol.
i'd rather have it be the ringlands anyways, then i have a reason to pull that bitch out and sleeve it.
ah **** it, i'm not taking apart my motor unless it's getting built. wether it's a head gasket or not, i'm sending my block to GE to get sleeved, and just rebuild the whole bottom end.
well thanks for help guys, sorry i was such an ***. it's just been pissing me off about my motor. i mean ****, i dump about 10 bottles of the 75 shot through there, and then 8lbs of boost for about 4 months and this is how my motor repays me? cheap *** honda heheh jk
JdmJah
16
02-19-2013 06:42 PM
