? on installing aftermarket pistons
Old Nov 21, 2004 | 10:53 AM
mrDFWmechanic's Avatar
Default ? on installing aftermarket pistons
okay i know when u install OEM pistons they have an arrow and you put them in so the arrow points toward the timing belt. but on like JE and ENDYN pistons they dont have an arrow, so does that mean u can put them in either way ???
Old Nov 21, 2004 | 11:01 AM
ogabudiah's Avatar
Default Re: ? on installing aftermarket pistons (iROCKtheSOHC)
There should be relief cut out on the intake side of the piston.
The intake has larger valves so the pistons have larger pockets on that side.
I don't know if the pistons will contact the valves if you put them in backwards but don't risk it.
Old Nov 21, 2004 | 11:10 AM
ohhhh i see what ur talkin about yea ok thanx.
Old Nov 21, 2004 | 11:30 AM
shadow103rd's Avatar
Default Re: (iROCKtheSOHC)
I thought the bigger reliefe pockets were on the exhaust side!
jon
Old Nov 21, 2004 | 06:58 PM
ogabudiah's Avatar
Default Re: (shadow103rd)
No they are on the intake side so that the incoming air can get in easier.
It is not neccessary on the exhaust side because it has pressure to get the exhaust out.
boostedb20z
Feb 10, 2008 05:35 PM
ogabudiah
Oct 17, 2004 06:37 PM
smokinsi
Jul 25, 2004 05:51 AM
Chuji
Jul 8, 2003 07:04 PM
turbohatch98
Jul 8, 2003 07:25 AM
