Couple of questions about oil lines & Wiring an o2 sensor to the greddy gauge
OK, a few questions I have are:
Is there any distribution block setup that I can use in place of the T's that connect the oil feed line from the block, the oil line to the turbo, the sensor for my oil warning light (stock cluster), the oil temp probe, and oil pressure probe.
I haven't hooked up an oil pressure probe but the T's I am using are getting out of control and it looks bad, I'd like to have some sort of box that I run the oil line into, and put all of the out's, sensors in it. Anyone know what I can do?
Also, is there any way to wire a different 4 wire o2 to the greddy 60mm warning gauge? We tried for hours to get a toyota 4 wire to work with it, we had the heater wires hooked up, but the yellow wire from greddy's box is 5 volts, and the toyota signal wire is like 3.5 volts. I thought about wiring in resistors, but I decided to just buy the greddy o2 (gauge came with car, sensor didn't), anyone know of another way?
Re: Couple of questions about oil lines & Wiring an o2 sensor to the greddy gauge (94lsboost)
I have found a few small blocks that allow 3 hook ups, but I need a larger one. Anyone??
I have a greddy o2 sensor on the way....so hopefully there is no way to wire another manufacturer's o2 to the greddy a/f warning system (toyota 4 wire o2 is the one in question).
bump
bump
i ♥ my honda
Global Mod
Global Mod
Golden Eagle makes a distribution block!
Try a yahoo search for oil distribution block or something along those lines.
There are tons of company’s that make um
Not sure on the sensor
EG-SIXV-TEC
03-06-2017 08:48 AM
