TURBO NOT CLOCKING!
Old Nov 21, 2004 | 11:50 PM
singlecamcrx's Avatar
Default TURBO NOT CLOCKING!
i have a T3 turbo and that sucker is NOT MOVING AN INCH. what do you guess suggest i do?
Old Nov 22, 2004 | 12:28 AM
incredteg3's Avatar
Default Re: TURBO NOT CLOCKING! (NitrousCrx)
with the car at idle or with you putting your digits in there and trying to turn it??
Old Nov 22, 2004 | 12:41 AM
sporkcrx's Avatar
First make sure all the bolts are loose. Sometimes it takes a little to bust it free. I've put a small pipe in the outlet sometimes to get some leverage and turn it. Be a man and dominate it
Old Nov 22, 2004 | 02:35 AM
Default Re: TURBO NOT CLOCKING! (sporkcrx)
been tried and done..i think its like pretty much rusted shut.. ima try soaking it in a bunch of PB blaster tomorrow.
Old Nov 22, 2004 | 03:53 AM
Btothe3rdDegree's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousCrx &raquo;</TD></TR><TR><TD CLASS="quote">been tried and done..i think its like pretty much rusted shut.. ima try soaking it in a bunch of PB blaster tomorrow.</TD></TR></TABLE>
wont help, i had the same problem, you need a torch. heat it up for 5 min. and tap it with a rubber mallet and i am sure it will work
Old Nov 22, 2004 | 08:58 AM
Del_Slowest's Avatar
Default Re: TURBO NOT CLOCKING! (Btothe3rdDegree)
don't use any oils or anything, just hit it with a damn hammer dude, be gentle yet firm....like you are with your woman
Old Nov 22, 2004 | 10:33 AM
Bailhatch's Avatar
Default Re: TURBO NOT CLOCKING! (Del_Slowest)
soaking it does help. heat helps more and a big pry bar the most. I made a tool type thing that is basicly a 4 foot pipe with a flat piece of 1/4" flat stock welded to the side of one end of the pipe. I drilled holes in the plate and bolted it to the oil drain flange. You just put the turbine housing in a vice, loosen the clamps and the pull as hard as you can while a friend hits the pipe with a hammer in the same direction. works like a charm
RACEPAK
Jan 22, 2008 05:50 PM
EG95D15VTEC
Jul 7, 2007 09:18 AM
RACEPAK
Feb 23, 2006 12:25 PM
a2sportcompacts
Aug 11, 2004 09:21 PM
71 mgb
Jul 20, 2003 06:34 PM
