NO ( PPM) Result.
Old Nov 19, 2004 | 03:13 PM
DaMmniTz's Avatar
Default NO ( PPM) Result.
Yesterday Result of smogging. I failed and got some advise from some members here about using Sea Foam and i got a bottle and mix it into my gasoline and went and re test it again today. And here's my outcome. . . .
Yesterday 11.18.04
Today 11/19.04
And that *** didn't pass me still. It's only by 101 . .
Since i went back the next day to smog it and it failed. He told me don't smog gas saver cars ( I had a crx 90) cause they're a pain in the ***.
f u c k you to smogging.
Old Nov 19, 2004 | 05:00 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: NO ( PPM) Result. (DaMmniTz)
Why is this in the FI forum?
Old Nov 19, 2004 | 07:07 PM
Pssst!'s Avatar
Excessive NOx is caused by excessive heat.
Heat above 2500°F in the conbustions chamber.
High compression and excess cooling system Temps. can be the cause.
You tryed Sea Foam, now try Water Wetter by Redline™
Old Nov 21, 2004 | 07:03 AM
.nate's Avatar
Unplug injector #3 and you should pass...
Old Nov 21, 2004 | 07:56 AM
non-VTEC's Avatar
turn the distributor back (retard timing) a few degrees and it will pass..........guarenteed.....
Old Nov 21, 2004 | 09:50 AM
Pssst!'s Avatar
Default Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">Unplug injector #3 and you should pass...</TD></TR></TABLE>
Won't pass cause of CEL light would be on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">turn the distributor back (retard timing) a few degrees and it will pass..........guarenteed..... </TD></TR></TABLE>
I Think This Might Work, If the Smog Tech does not check your timing.
Old Nov 21, 2004 | 12:17 PM
.nate's Avatar
Default Re: (Pssst!)
No the CEL won't be on Stop thinking and start knowing
Modified by .nate at 3:33 PM 11/21/2004
Old Nov 21, 2004 | 12:47 PM
Sonny's Avatar
It's not up the "***" to pass your or not. The machines reads your numbers. If they are not in range, you fail.
You can retard the timing or bump up the fuel pressure. Almost all of them check timing though and retarding it is not an option in Cali if it falls outside the +/- 2 deg spec.
I failed with high NOx repeatedly...engine was completely rebuilt. I was super clean on HC and CO.
I fixed it with more fuel pressure.
Sonny
avrfan
May 13, 2015 06:29 PM
Ge-money
Oct 15, 2012 07:54 PM
langjairicer
May 28, 2010 01:13 AM
EdBoon
16
Dec 2, 2004 01:47 PM
DaMmniTz
11
Nov 20, 2004 04:42 PM
