ls/vtec turbo
Old Nov 20, 2004 | 03:49 PM
speedfreak0920's Avatar
Default ls/vtec turbo
i have a b18b that i want to vtec AND turbo. should i stick with my stock lower comp. pistons? should i leave the b18b absolutely stock and just slap on a bone stock b16/b18c1 head and turbo that? if so how much power should i make if tuned well? will prob. use a 14b and johnyracecar fmic,dsm injectors,hondata or fmu(depending on my budget),etc. will only boost around 7-8 psi. thanks
Old Nov 20, 2004 | 05:02 PM
donkiman's Avatar
Default Re: ls/vtec turbo (speedfreak0920)
well i would definetly go turbo if i were you but for reliability issues i would most definetly without a doubt instead of buying a vtec head would buy stronger pistons and rods. boost that bitch without vtec. vtec is good and all but it doesnt even compare to another 150whp you could get from upin the boost.
Old Nov 20, 2004 | 06:57 PM
-_-'s Avatar
-_-
Default Re: ls/vtec turbo (donkiman)
^^^ like he said, use the money to buy stronger internals and boost the hell outta the thing.
Old Nov 20, 2004 | 07:22 PM
spooledex's Avatar
Default Re: ls/vtec turbo (-_-)
Um I think LS + Vtec + boost =
Old Nov 20, 2004 | 08:16 PM
incredteg3's Avatar
Default Re: ls/vtec turbo (spooledex)
umm yea i agree with the first two guys. or do it all build the bottom end make sure the head is in good condition and then turbo that. I think you will spend a lot of $$$ and time and headache to pop the hood, have everyone go uooo ahhh and then see you do like a 13 sec. pass. then they will go ohhhh noooo
me=built ls and love it
Old Nov 21, 2004 | 09:17 AM
i want to vtec and boost with a small turbo because i plan on roadcoursing next year. small turbo = quick spool!
Old Nov 21, 2004 | 11:04 AM
mrDFWmechanic's Avatar
get better pistsons and rods and own those that have vtec !
Old Nov 21, 2004 | 01:36 PM
-_-'s Avatar
-_-
Default Re: (speedfreak0920)
If you invest some time into picking out the right tool the turbo will be quick enough. Obviously there will be some lag, but the extra boost your running, and higher grade turbo (thanks to the upgraded internals you used money to buy -_-) will more than make up for vtec.
To be honest if your gonna be racing/autocrossing with this or anything of the like id spend the money first on suspension...
Old Nov 21, 2004 | 03:09 PM
boosted91rex's Avatar
Default Re: (-_-)
i have the exact same setup that u are talking about and it made good power but i was also running 10psi man that bitch pulled but i blew it up like 5 days later so im with the rest of guys on building a block that way your making good power and its reliable im going to try another stock block with new rings and bearings and see how that works and im also going to build another block on the side
Old Nov 21, 2004 | 09:06 PM
finally! some1 who has almost the same set up as i want. thanks for the info man. how much power did u make? was it tuned right? thnx
bigmike305
Sep 29, 2009 04:15 PM
civicboy1128
Aug 5, 2008 12:39 PM
leroyb
Jul 11, 2008 06:18 PM
JDMike418
Jan 19, 2008 07:30 AM
RSRintegra90
May 11, 2005 08:09 AM
