oil leak at downpipe
Old Nov 22, 2004 | 06:07 PM
krazn's Avatar
Default oil leak at downpipe
ok guys, i need help. i tried search...but i didn't find anything useful to me. I've been getting white smoke ever since i installed my turbo 4 months ago. it smokes alot at idle....not all the time....but i notice it alot especially when i'm letting my car warm up in the morning. here are the things people have told me to check, and some of the research i found here w/ the search function...
first- did a compression test. came out 220 across the board
second- test for head gasket. while car was warm, i opened radiator cap to see if there were any bubbles. I saw none.
third- test for turbo seal- i took apart IC pipes to see if oilly residue was visible. i saw nothing.
about a week ago, i boosted my car up from 7 psi to 10 psi. at 10 psi, my car felt strong, but i was leaking at the down pipe. when i dropped it back down to 7 psi, there were no more leaks. what could cause this problem? and why do i have white smoke? help please
Old Nov 22, 2004 | 06:20 PM
stealthmode62's Avatar
Default Re: oil leak at downpipe (krazn)
I'm not sure what you mean by leaking at the downpipe, but if your downpipe is clean, and your headgasket is good, I would say possibly valve seals. Possibly something going on with the excess pressure in the crankcase. Try routing the pcv to a catch can and see if that helps the smoke.
On the boost pressures, check for leaks all the way from where the manifold meets the turbo to the charge pipe to throttle body connections.
Old Nov 22, 2004 | 06:28 PM
Jockobo's Avatar
so oil's dripping out of the downpipe? mine did that when the oil seals went bad on the exhuaslt side...
krazn's Avatar
Default Re: oil leak at downpipe (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> I'm not sure what you mean by leaking at the downpipe, but if your downpipe is clean, and your headgasket is good, I would say possibly valve seals. Possibly something going on with the excess pressure in the crankcase. Try routing the pcv to a catch can and see if that helps the smoke.
On the boost pressures, check for leaks all the way from where the manifold meets the turbo to the charge pipe to throttle body connections. </TD></TR></TABLE>
well i meant oil was leaking at the down pipe bolts when i boosted it at 10 psi.
thanks for the response...i've been meaning to put on a catch can. maybe that might help my smoke. right now i have just a rubber tube hanging freely from the valve cover breather.
how can i check valve seals?
Old Nov 22, 2004 | 06:29 PM
krazn's Avatar
Default Re: oil leak at downpipe (Jockobo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jockobo &raquo;</TD></TR><TR><TD CLASS="quote">so oil's dripping out of the downpipe? mine did that when the oil seals went bad on the exhuaslt side...</TD></TR></TABLE>
dripping out fo the downpipes bolts, only at 10 psi. when i'm down at 7...everything is ok again.
Old Nov 23, 2004 | 02:59 PM
krazn's Avatar
hmm...i still dont have an answer to this. can anyone help?
Old Nov 24, 2004 | 01:43 AM
B.S._TURBO's Avatar
IT sounds like your turbo seals and bearings are blown, but maybe not. what weight of oil do you run. I run 20W-50. Light oil will destroy your turbo seals and bearings.
Old Nov 24, 2004 | 03:05 AM
crispydee's Avatar
Default Re: oil leak at downpipe (derekhart)
white smoke is not you turbo seals unless you have a water cooled turbo. Oil makes blue smoke, if its white its water or a it could be over fuelling a little bit at idle. Whats the weather like? my car is fine but on a cold day it has loads of white smoke at idle, specially until it warms up because of the condensation that has built up in the exhaust over night.
Old Nov 24, 2004 | 05:37 PM
B.S._TURBO's Avatar
Default Re: oil leak at downpipe (crispydee)
i didn't see the white smoke part. he is right it prbably is coolant.
Atauto
Honda CR-V & Element
Aug 27, 2016 08:13 AM
EK9-T
Aug 5, 2009 03:26 AM
jdm2teg
Feb 1, 2006 08:50 PM
Typeron
Jan 5, 2006 07:37 PM
froggie3kb
19
Oct 30, 2003 06:15 PM
