Upgrade coils, electrical?
Old Nov 21, 2004 | 05:50 PM
Forrest Gump 9's Avatar
Default Upgrade coils, electrical?
Hi guys, I tried to search, but couldn't find anything useful so I post here.
My car is your typical EG with the GSR swap. It is fully built with 9.0 CR pistons, SC61 turbo, Hondata. It have ran the best of 11.5's @ 122mph. But yesterday I went down to the track again, and the car just keep on missing at the top of third gear and fourth gear. I changed the plugs, but no luck. So I called it quit. As far as the ignition go, I have stock distributor, MSD cap, MSD compact coil, and NGK wire. The spark plugs were gap at .025.
What else can I upgrade to get rid of the missing problem? Thanks in advance!!
Old Nov 21, 2004 | 05:57 PM
MooreBoost's Avatar
Default Re: Upgrade coils, electrical? (Turbo9Nut)
I prefer OEM wires, and I would switch to a stronger coil.
Edit- the 6al maybe?
Old Nov 21, 2004 | 06:36 PM
Joseph Davis's Avatar
Default Re: Upgrade coils, electrical? (tegunderpressure)
6AL is not a coil, it is an ignition signal modifier box that has been known to cost power. The MSD blaster coil with otherwise stock Honduh ignition should work fine.
I think there's a maintainance problem with cap/wires/rotor/coil, because your ignition setup is fine as is. Except the wires... tegunderpressure's right about OEM's being the best.
Old Nov 21, 2004 | 06:37 PM
15psi of fun's Avatar
i have about the same set up
im going to upgrade to a msd dig7 and hvc2 coil
Old Nov 21, 2004 | 06:47 PM
MooreBoost's Avatar
Default Re: Upgrade coils, electrical? (J. Davis)
I always thought the 6al boxes or whatever amplified spark? I guess I'm wrong though, trust J. Davis.
Old Nov 21, 2004 | 06:48 PM
Default Re: Upgrade coils, electrical? (15psi of fun)
All of the cap and rotor, coil, have less than 600 miles.
Cpt Ben
Apr 18, 2006 10:21 PM
roterx7
Apr 1, 2006 05:23 AM
92lstcvc
Mar 19, 2006 07:00 AM
mookhaasa
Sep 27, 2005 06:17 AM
Forrest Gump 9
Nov 21, 2004 06:18 PM
