turbo mani - help
Old Nov 23, 2004 | 06:23 PM
dimotorsports's Avatar
Default turbo mani - help
Can a D16z6 EX cast manifold be used on a D16y8 as a turbo mani?
I heard a HF can, but what about the EX off a Z6?
Thanks.
Old Nov 23, 2004 | 06:28 PM
B18C1CYA's Avatar
Default Re: turbo mani - help (dimotorsports)
it should fit they are both d-series ,
Old Nov 23, 2004 | 07:23 PM
Default Re: turbo mani - help (B18C1CYA)
Anyone tried it?
Does it work for sure?
Old Nov 24, 2004 | 01:30 AM
B.S._TURBO's Avatar
I will work. Any d-series manifolds will intermix with each other.
Old Nov 24, 2004 | 05:33 PM
'm hearing this mani may cause turbo creep..
any of you ever heard that?
Old Nov 24, 2004 | 05:40 PM
*Boostwerks*'s Avatar
What the hell are you guys talking about?
The EX manifold as far as I know is almost like a header.
the CX and HF manifolds are the ones you would need for a turbo manifold. A company on homemadeturbo.com makes adapter plates.
BTW, I have a spare HF if you need it...
Old Nov 24, 2004 | 05:48 PM
B.S._TURBO's Avatar
Default Re: (Bryson)
you can still get a ex manifold to work but he is right cx and hf manifolds are way easier to fab up.
Old Nov 24, 2004 | 06:05 PM
Default Re: (derekhart)
whats the big difference between using the EX over the CX of HF?
And yes.. your right.
The EX is like a header on 99 and 00, but before that they were cast manifolds and the one I have is off a 95.
Old Nov 24, 2004 | 06:21 PM
Tad's Avatar
Tad
NO dude,
all those people saying yes are probly just thinking you want to use it as a normal header.
the ex manifold wont work because it is a 4-2-1 setup, it turns into 2pipes, that won't work well at all to run into a turbo. also it hangs down super low compared to the cx/hf
the cx/hf is used alot because it's really short and stubby, and all 4 tubes run into one outlet that happens to be a good size to hook a turbo up to.
reason for this is it's built to have a cat sitting right up against it, while the ex's cat sits further down along the exhuast path.
Old Nov 24, 2004 | 07:26 PM
Default Re: (Tad)
makes sense
Old Nov 24, 2004 | 08:11 PM
B.S._TURBO's Avatar
Default Re: (dimotorsports)
ex is 4-2-1. I didn't know that. cool I learned something today. thanks
Old Nov 24, 2004 | 11:31 PM
DRIVENRacing's Avatar
correct... ex and si manifold(s) is pretty much a 4-2-1 header... the only one that can be used as a turbo manifold with a t3 addptr. plate would be the ones that have the cat on them.. if im not mistaken it would be hf, hx, and cx...
1990hondaHF
Apr 19, 2006 05:25 PM
d16X
Jun 19, 2005 11:02 AM
USDM 4G VTEC
Aug 19, 2002 10:37 PM
