Oil in Spark plug
Old Nov 23, 2004 | 06:07 AM
fjt's Avatar
fjt
Default Oil in Spark plug
What could be the problem?..
Its a D16y7 Motor
Car iddles fine, no smoking thru the exhaust, just when the car starts cold in the morning but when it warms up no smoking at all the rest of the day.Car is not overheating either. Oil level checked every 2 days and its not burning/consuming oil.Oil levels are fine.
I checked my plugs and #4 plug had oil all over..Spark plug "head" had oil there was oil in the spark plug screw even the Spark plug Wire had oil... Its the 2nd time in a week i check the plugs and it comes out with oil..Just that spark plug..all others are fine
The Oil seals around the Spark plugs in the valve cover were replaced with new ones 2-3 months ago.
Car is not tuned yet.
Old Nov 23, 2004 | 08:33 AM
RyanEJ8's Avatar
Default Re: Oil in Spark plug (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">
The Oil seals around the Spark plugs in the valve cover were replaced with new ones 2-3 months ago.</TD></TR></TABLE>
This is what I was going to suggest as I had the same problem. I'd check them anyways and see if maybe they were defective.
Old Nov 23, 2004 | 08:52 AM
fjt's Avatar
fjt
Default Re: Oil in Spark plug (RyanCivic2000)
Hmm ok..Actually i pulled out the spark plug wire and checkes and it seem there is a lil bit of oil at the top of the S.Plug tube so im guessing that specific seal might be fed up..maybe it stopped sealing well..
Thanks
CRZ1
Apr 26, 2009 08:59 PM
St3v3
Dec 27, 2004 04:01 PM
JDM-EJ1
15
Nov 17, 2004 05:32 PM
NickR
May 15, 2004 11:22 AM
Doogie Howser
May 22, 2002 11:59 AM
