hp #'s using a t3 60-1?
Old Nov 20, 2004 | 03:00 PM
GsRHatchy1320's Avatar
Default hp #'s using a t3 60-1?
just curious on what type of hp numbers is anyone getting out of there t3 60-1
anyone have any experience with them.just purchase mine .63turbine .70 comp
goal is to reach 4-425 hp
Old Nov 20, 2004 | 03:56 PM
turboEGhatch's Avatar
Default Re: hp #'s using a t3 60-1? (GsRHatchy1320)
500+ WHP has been done many a time on T3/60-1's.
Old Nov 20, 2004 | 05:36 PM
tyrone27's Avatar
Default Re: hp #'s using a t3 60-1? (turboEGsedan)
at what boost level?
Old Nov 20, 2004 | 05:42 PM
Default Re: hp #'s using a t3 60-1? (tyrone27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyrone27 &raquo;</TD></TR><TR><TD CLASS="quote">at what boost level?</TD></TR></TABLE>
Mid 20's. The 60-1 wheel is most efficient at quite low boost pressures (see url=http://www.turbocalculator.com/compressor-maps/t04-60-1.jpg]here[/url]) compared to most turbos. That peaks out at a 2.00 pressure ratio, go look at a T66's map and it's peak efficiency island runs up to a 3.4 pressure ratio, or around 35 pounds of boost! 425 WHP should be achieved at under 20 pounds of boost, i'd guess around 17 or 18.
Old Nov 20, 2004 | 06:11 PM
tyrone27's Avatar
damn I'm only running 12 I thought I should up the boost to 20
RedTT
Mar 27, 2007 01:52 PM
blackpearlcivic
Jan 26, 2006 05:24 PM
MikeD718
Dec 21, 2005 07:16 PM
ying_YANGtwin
Dec 16, 2004 05:55 PM
60-1
Oct 9, 2003 06:12 PM
