WHP expectations ?
Old Jul 23, 2005 | 02:06 PM
crazyimport's Avatar
Default WHP expectations ?
I finally have finished my build and i havent drivin it yet until i get tuned... what should i be looking for when i the dyno anyone have a similar setup ?
Precision 880cc injectors
CM stage 3 clutch
BLITZ BOV
Blitz SBC i-D boost controller
Intercooler
26" x 12" x 3"
Turbo
Garrett t3/t04e 60 trim w/ .63 a/r
Drag turbo manifold
tiAl 38 mm wastegate
3" exhaust with no cat
walbro 255 fuel pump
b16a2 81.5mm
Stock sleeves
JE 9.0:1 pistons
ITR valvetrain
eagle rods
all new bearings gaskets
ITR tranny w/ lsd
Im gonig to running 20 psi on RACE gas..
and 15 on 94 pump gas
Modified by crazyimport at 11:19 PM 7/23/2005
Old Jul 23, 2005 | 02:09 PM
jmcmil6's Avatar
Default Re: WHP expectations ? (crazyimport)
id say maybe 450whp
depending on fuel management and tuning
Old Jul 23, 2005 | 02:11 PM
Default Re: WHP expectations ? (jmcmil6)
chipped ecu..
crome
Old Jul 23, 2005 | 02:16 PM
jmcmil6's Avatar
what kind of cams?
Old Jul 23, 2005 | 02:18 PM
stock b16 w/ itr valvetrain.. sorry forgot
Old Jul 23, 2005 | 02:22 PM
turboEGhatch's Avatar
I'll guess 425 WHP @ 20 psi, and 350 @ 15.
jmcmil6's Avatar
be better off w/ auto cams or gsr ..if u wana keep it simple
Old Jul 23, 2005 | 02:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmcmil6 &raquo;</TD></TR><TR><TD CLASS="quote">be better off w/ auto cams or gsr ..if u wana keep it simple</TD></TR></TABLE>
I've never seen ANYTHING that shows the automatic B16 cams to be bigger than the manual B16 cams. Auto LS cams are smaller than stick LS cams, it's the same for virtually every car maker out there, there is no reason for auto B16 cams to be bigger. And while we're on that subject, he'd be better off to get ITR/CTR cams off the bat instead of moving to GSR's.
Old Jul 23, 2005 | 03:08 PM
Default Re: WHP expectations ? (turboEGhatch)
for the amount of gains.. ill just stick with my b16 cams...
im hoping to run a mid 11 with mysetup
i have 24" slicks too
hopefully i can reach it
Old Jul 23, 2005 | 03:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyimport &raquo;</TD></TR><TR><TD CLASS="quote">for the amount of gains.. ill just stick with my b16 cams...
http://forums.evans-tuning.com...=2341
A 25% gain in torque at 2000 RPM's and as much as a 30 ft-lb gain in the mid range isn't worth it?
Old Jul 23, 2005 | 04:03 PM
Si Shane's Avatar
the guy i know barely made 400whp with a b16 and that same turbo at 20psi on c16.
jg edelbrock manifold, equal lenght exhaust manifold, 3" downpipe, low comp b16, stock head. so dont get too excited
Old Jul 23, 2005 | 05:07 PM
Default Re: WHP expectations ? (Si Shane)
id be more then happy with 400 whp
Old Jul 24, 2005 | 01:18 AM
mattcivic's Avatar
ive been wanting to ask a similar question tell me what u guys think i might get it will be running in a few weeks just waiting on the head and some misc ****.
sleeved gsr 84mm
9 to 1's
eagle rods
balaced and blue'd
headwork by portflow
revhard springs & retainers
gsr cams
victor X IM
str 70mm TB
MSD SCI
hytech manifold
3 inch DP
RC 1,000's
pt67 p trim turbo
water-----&gt;air IC
tial WG and BOV
tuned with s200
i think thats it but the guy who is going to be tuning my car thinks were gunna be pushing 17-18 lbs on pump gas but that may be different we wont know till we get it on the dyno. i want to hit 500hp on pump gas but i dont think it will quite get there but i guess well see what do u guys think????
Old Jul 24, 2005 | 09:57 AM
T4eg's Avatar
Default Re: WHP expectations ? (mattcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic &raquo;</TD></TR><TR><TD CLASS="quote">ive been wanting to ask a similar question tell me what u guys think i might get it will be running in a few weeks just waiting on the head and some misc ****.
sleeved gsr 84mm
9 to 1's
eagle rods
balaced and blue'd
gsr cams
victor X IM
str 70mm TB
MSD SCI
hytech manifold
3 inch DP
RC 1,000's
pt67 p trim turbo
tial WG and BOV
tuned with s200
i think thats it but the guy who is going to be tuning my car thinks were gunna be pushing 17-18 lbs on pump gas but that may be different we wont know till we get it on the dyno. i want to hit 500hp on pump gas but i dont think it will quite get there but i guess well see what do u guys think???? </TD></TR></TABLE>
u should be able to break 500 on 17-18lbs no problem. i have simialr setup just air to air IC, 83mm motor, no headwork and did 460 on 14lbs (95 degree day no cam gear adjustment)
Old Jul 24, 2005 | 10:10 AM
JDMs1eeper's Avatar
Id say 360-410 with your stock cams. To run mid 11's 300whp flat would be more than enough. (as long as your car isnt a pig)
Old Jul 24, 2005 | 10:29 AM
Default Re: WHP expectations ? (JDM S1eeper)
EK h/b ...
i think i will hit about 410 on race gas
Old Jul 24, 2005 | 11:00 AM
JDMs1eeper's Avatar
kewl, if this tells you anything my friend has an EK w/ an LSvtec that makes 400whp. He runs 11.1 or 11.2 i believe with a 125mph trap. So like i said.. 300 and decent driving will still be 11's i'm sure
EDIT: w/ 20psi on a drag kit
and me saying "300" meaning, even if you dont hit your goal for some reason, you should still be in the 11's like your 1/4 goals you have listed
Old Jul 24, 2005 | 11:11 AM
thats sweet... but elevations here in canada always make times worse..
guy is hitting about 390 whp in his gsr turbo and he's running high 11's on slicks...
so im aiming for 11.5 - 11.9 and im happy
Old Jul 24, 2005 | 12:14 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyimport &raquo;</TD></TR><TR><TD CLASS="quote">thats sweet... but elevations here in canada always make times worse..
so im aiming for 11.5 - 11.9 and im happy </TD></TR></TABLE>
true true, good luck man
Old Jul 24, 2005 | 12:29 PM
Si Shane's Avatar
mid to high 12's all day on street tires is a realistic goal for 400whp in a daily driven car. thats more speed and power than most should ever need
Old Jul 24, 2005 | 04:35 PM
vaporboy12's Avatar
400 if your lucky on b16 cams
Old Jul 24, 2005 | 09:43 PM
mattcivic's Avatar
Default Re: WHP expectations ? (T4eg)
thanx T4eg im not trying to get my hopes up it should be running and driving in about 4 weeks or so.... there will be a video of the dyno and all cant wait its like x-mas but i know what im getting and cant have it yet
Old Aug 2, 2005 | 09:18 PM
i'll be sure to post my dyno results next week
builtboostedteg
May 2, 2007 03:30 PM
crazyimport
Aug 10, 2005 03:22 PM
crazyimport
Apr 25, 2005 11:15 PM
C-Murdock
Feb 20, 2003 07:53 PM
