Overheating STILL!!!!!!
Old Jul 23, 2005 | 08:07 AM
GorData's Avatar
Default Overheating STILL!!!!!!
Here is my setup First,
1.8 GSR
JE Pistons, Scat Rods
Golden Eagle Block Guard
oem headgasket
Drag Turbo KIT
FLUIDYNE Full size radiator For Integra
TWO 12" Fans pushing 1450 CFM
No Thermostat
It started to Overheat after I changed the pistons and rods
So I took of the head and took to the machine shop thinking that the Head was Bent.
Installed and the same Problem.
Its funny cause it Overheats the same with or without the thermostat.
I am thinking it is problem the Block Guard or the Water pump.
It doesnt Over flow or anything, I have changed the headgasket twice.
Its random too. It does it standing, sometimes Running. It doesnt do it in any other.
I am puzzled at what it is??
Any Input Would be appreciated.
Old Jul 23, 2005 | 08:32 AM
dustin's Avatar
Default Re: Overheating STILL!!!!!! (GorData)
blockguards are nothing but trouble.
Old Jul 23, 2005 | 08:52 AM
Muckman's Avatar
Moderator in Chief
Did you bleed the coolant system?
Old Jul 23, 2005 | 01:40 PM
GorData's Avatar
Default Re: Overheating STILL!!!!!! (Muckman)
Of Course I have bleed the system LIke a thousand Times. I am going to get rid of the block guard, Can I still make reliable power with just the Pistons and Rods???
Old Jul 23, 2005 | 01:59 PM
N20civicB18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GorData &raquo;</TD></TR><TR><TD CLASS="quote">Of Course I have bleed the system LIke a thousand Times. I am going to get rid of the block guard, Can I still make reliable power with just the Pistons and Rods???</TD></TR></TABLE>
I always see a GSR hatchback running high 10's on just pistons and rods at the track, dont know about reliability though just its always there
Old Jul 23, 2005 | 07:06 PM
m R g S r's Avatar
why no thermo? why did you put the blockguard in there? did you search for the numerous dynos with cars making tons of power with just pistons and rods?
Old Jul 23, 2005 | 07:14 PM
JDMs1eeper's Avatar
Sorry your haveing so much trouble. I've had the same problem. Good Luck
Old Jul 23, 2005 | 07:23 PM
Slavko's Avatar
Default Re: Overheating STILL!!!!!! (JDM S1eeper)
Check if your water pump is working. Since you have no thermostat now. Just start the car and open the radiator cap and check if the water circulates.
Try this and then we can move on to other things.
Old Jul 23, 2005 | 10:06 PM
GorData's Avatar
Default Re: Overheating STILL!!!!!! (Slavko)
I really appreciate You guys Helping me, I am going to check if there is antifreeze flowing. I will let You guys know on monday.
Old Jul 23, 2005 | 10:32 PM
mamaboy's Avatar
throw the thermostat back on. we had to throw the thermostat back onto my friends bronco rock crawler because it was overheating. the coolant doesn't have sufficient time to cool down through the radiator.
Old Jul 24, 2005 | 06:14 AM
GorData's Avatar
Default Re: Overheating STILL!!!!!! (mamaboy)
it had the thermostat on AT first, I bought a spoon one that opens at 160 and that didnt help
Old Jul 25, 2005 | 01:44 PM
edge099's Avatar
i had the same problem with my car what i did i bought arp head studs and there said to touge the head down 76ibs but honda recommend 96ibs so just check that out i dont know if that will help but good luck
mikeblackcivic
Texas -OK -LA (Sales)
Mar 18, 2014 05:22 PM
Red_EM1
Jun 26, 2004 08:41 PM
Nextelbuddy
Feb 19, 2004 07:24 PM
2000Accord5sp
Aug 21, 2002 05:12 PM
